주요 콘텐츠로 건너뛰기
Google Pixel 9 Motherboard Replacement
필요한 것
  1. Google Pixel 9 Motherboard Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 3개
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 Motherboard Replacement, Adhesive information: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Adhesive information: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Adhesive information: 2 단계, 이미지 3개 중 3개
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Google Pixel 9 Motherboard Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 2개
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Google Pixel 9 Motherboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9 Motherboard Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Google Pixel 9 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Google Pixel 9 Motherboard Replacement, Remove the back glass: 8 단계, 이미지 1개 중 1개
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Google Pixel 9 Motherboard Replacement, Remove the upper board cover: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Google Pixel 9 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to remove the upper board cover.
  11. Google Pixel 9 Motherboard Replacement, Remove the midframe: 11 단계, 이미지 1개 중 1개
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Google Pixel 9 Motherboard Replacement, Peel up the flash cable: 12 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Peel up the flash cable: 12 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Google Pixel 9 Motherboard Replacement, Remove the midframe: 13 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Remove the midframe: 13 단계, 이미지 2개 중 2개
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Google Pixel 9 Motherboard Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the battery connector.
  15. Google Pixel 9 Motherboard Replacement, Disconnect the 5G mmWave antenna: 15 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the 5G mmWave antenna: 15 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Disconnect the 5G mmWave antenna: 15 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  16. Google Pixel 9 Motherboard Replacement, Remove the 5G mmWave antenna: 16 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Remove the 5G mmWave antenna: 16 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Remove the 5G mmWave antenna: 16 단계, 이미지 3개 중 3개
    • Remove the 5G mmWave antenna.
    • A small flex cable attaches to the back of the antenna with a press connector. You may need to reconnect it if it falls off.
    • During reassembly, insert the antenna so it's between the frame and the small metal bracket near the top right corner.
  17. Google Pixel 9 Motherboard Replacement, Remove the antenna board cover: 17 단계, 이미지 1개 중 1개
    • Use a 3IP Torx Plus driver to remove the 5.4 mm-long screw securing the antenna board cover.
  18. Google Pixel 9 Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to remove the antenna board cover.
  19. Google Pixel 9 Motherboard Replacement, Disconnect the autofocus cable: 19 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the autofocus cable: 19 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the autofocus connector from the motherboard.
  20. Google Pixel 9 Motherboard Replacement, Disconnect the antenna cable: 20 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the antenna cable: 20 단계, 이미지 2개 중 2개
    • Insert one arm of a pair of angled tweezers under the metal neck of the antenna board's coaxial antenna cable.
    • Lift straight up to disconnect the antenna.
  21. Google Pixel 9 Motherboard Replacement, Disconnect the front camera: 21 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the front camera: 21 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the front camera press connector.
  22. Google Pixel 9 Motherboard Replacement, Disconnect the interconnect cables: 22 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the interconnect cables: 22 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Disconnect the interconnect cables: 22 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to pry up and disconnect the top two interconnect cable press connectors from the bottom edge of the motherboard.
  23. Google Pixel 9 Motherboard Replacement, Unscrew the motherboard: 23 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the motherboard:
    • One 2.9 mm-long 3IP Torx Plus screw
    • One 5 mm-long standoff screw
  24. Google Pixel 9 Motherboard Replacement, Lift up the motherboard: 24 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Lift up the motherboard: 24 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Lift up the motherboard: 24 단계, 이미지 3개 중 3개
    • Insert the tip of a spudger underneath the bottom right corner of the motherboard.
    • Lift up with the spudger to dislodge the motherboard.
    • Lift the motherboard up until you can grip it with your fingers.
  25. Google Pixel 9 Motherboard Replacement, Remove the motherboard: 25 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Remove the motherboard: 25 단계, 이미지 2개 중 2개
    • Remove the motherboard.
  26. Google Pixel 9 Motherboard Replacement, Thermal pad reassembly information: 26 단계, 이미지 3개 중 1개 Google Pixel 9 Motherboard Replacement, Thermal pad reassembly information: 26 단계, 이미지 3개 중 2개 Google Pixel 9 Motherboard Replacement, Thermal pad reassembly information: 26 단계, 이미지 3개 중 3개
    • Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
    • If the pad is undamaged, skip the rest of this step.
    • If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
    • Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
    • Apply a new thermal pad to its spot on the frame.
  27. Google Pixel 9 Motherboard Replacement, Disconnect the flash: 27 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the flash: 27 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the flash connector from the motherboard.
  28. Google Pixel 9 Motherboard Replacement, Disconnect the wide camera: 28 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the wide camera: 28 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the wide camera.
  29. Google Pixel 9 Motherboard Replacement, Disconnect the ultrawide camera: 29 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Disconnect the ultrawide camera: 29 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the ultrawide camera.
  30. Google Pixel 9 Motherboard Replacement, Remove the motherboard: 30 단계, 이미지 2개 중 1개 Google Pixel 9 Motherboard Replacement, Remove the motherboard: 30 단계, 이미지 2개 중 2개
    • Remove the rear camera module from the motherboard.
  31. Google Pixel 9 Motherboard Replacement: 31 단계, 이미지 1개 중 1개
    • Only the motherboard remains.
결론
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
155,196 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,589개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 52
지난 30일: 229
전체 시간: 3,013
