주요 콘텐츠로 건너뛰기
Google Pixel 9 Pro Fold Back Cover Replacement
필요한 것
  1. Google Pixel 9 Pro Fold Back Cover Replacement, Prepare your phone for disassembly: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold Back Cover Replacement, Separate the back cover adhesive: 3 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Separate the back cover adhesive: 3 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement, Separate the back cover adhesive: 3 단계, 이미지 3개 중 3개
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold Back Cover Replacement: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold Back Cover Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 5 단계, 이미지 3개 중 3개
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold Back Cover Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold Back Cover Replacement, Remove the top bracket screw: 7 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Remove the top bracket screw: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold Back Cover Replacement, Remove the top bracket: 8 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Remove the top bracket: 8 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold Back Cover Replacement, Disconnect the back cover cable: 9 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Disconnect the back cover cable: 9 단계, 이미지 2개 중 2개
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold Back Cover Replacement, Remove the back cover: 10 단계, 이미지 1개 중 1개
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold Back Cover Replacement, End of disassembly: 11 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  12. Google Pixel 9 Pro Fold Back Cover Replacement, Remove the old adhesive: 12 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Remove the old adhesive: 12 단계, 이미지 2개 중 2개
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  13. Google Pixel 9 Pro Fold Back Cover Replacement, Remove the back cover liners: 13 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Remove the back cover liners: 13 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement, Remove the back cover liners: 13 단계, 이미지 3개 중 3개
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  14. Google Pixel 9 Pro Fold Back Cover Replacement: 14 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 14 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 14 단계, 이미지 3개 중 3개
    • Peel off the remaining clear liners on the outside of the back cover.
  15. Google Pixel 9 Pro Fold Back Cover Replacement, Compare your adhesive: 15 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Compare your adhesive: 15 단계, 이미지 2개 중 2개
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
  16. Google Pixel 9 Pro Fold Back Cover Replacement, Apply the new adhesive: 16 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Apply the new adhesive: 16 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement, Apply the new adhesive: 16 단계, 이미지 3개 중 3개
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  17. Google Pixel 9 Pro Fold Back Cover Replacement: 17 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 17 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  18. Google Pixel 9 Pro Fold Back Cover Replacement: 18 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 18 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 18 단계, 이미지 3개 중 3개
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  19. Google Pixel 9 Pro Fold Back Cover Replacement: 19 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 19 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 19 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  20. Google Pixel 9 Pro Fold Back Cover Replacement: 20 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 20 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 20 단계, 이미지 3개 중 3개
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  21. Google Pixel 9 Pro Fold Back Cover Replacement, Reconnect the back cover cable: 21 단계, 이미지 1개 중 1개
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  22. Google Pixel 9 Pro Fold Back Cover Replacement, Reinstall the top bracket: 22 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Reinstall the top bracket: 22 단계, 이미지 2개 중 2개
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  23. Google Pixel 9 Pro Fold Back Cover Replacement: 23 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 23 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  24. Google Pixel 9 Pro Fold Back Cover Replacement, Remove the secondary liner: 24 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Remove the secondary liner: 24 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  25. Google Pixel 9 Pro Fold Back Cover Replacement: 25 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 25 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 25 단계, 이미지 3개 중 3개
    • Peel off the secondary liner to expose the adhesive.
  26. Google Pixel 9 Pro Fold Back Cover Replacement, Secure the back cover: 26 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement, Secure the back cover: 26 단계, 이미지 2개 중 2개
    • Align the top edge of the back cover with the frame and press down to adhere it.
  27. Google Pixel 9 Pro Fold Back Cover Replacement: 27 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Back Cover Replacement: 27 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Back Cover Replacement: 27 단계, 이미지 3개 중 3개
    • Press along the perimeter of the back cover to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
결론
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,530 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,603개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 117
전체 시간: 1,370
