주요 콘텐츠로 건너뛰기
Google Pixel 9 Pro Fold Loudspeaker Replacement
필요한 것
  1. Google Pixel 9 Pro Fold Loudspeaker Replacement, Prepare your phone for disassembly: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Loudspeaker Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the back cover adhesive: 3 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the back cover adhesive: 3 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the back cover adhesive: 3 단계, 이미지 3개 중 3개
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold Loudspeaker Replacement: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 4 단계, 이미지 3개 중 3개
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold Loudspeaker Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 5 단계, 이미지 3개 중 3개
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold Loudspeaker Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 6 단계, 이미지 3개 중 3개
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket screw: 7 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket screw: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket: 8 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the top bracket: 8 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the back cover cable: 9 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the back cover cable: 9 단계, 이미지 2개 중 2개
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover: 10 단계, 이미지 1개 중 1개
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket screws: 11 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket screws: 11 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
  12. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket: 12 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket: 12 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the base battery bracket: 12 단계, 이미지 3개 중 3개
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
  13. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the base battery: 13 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the base battery: 13 단계, 이미지 2개 중 2개
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
  14. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the USB-C port board cable: 14 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the USB-C port board cable: 14 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the USB-C port board cable press connector.
  15. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket screws: 15 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket screws: 15 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the vibrator bracket.
  16. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket: 16 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the vibrator bracket: 16 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to lift the vibrator bracket off the frame and remove it.
  17. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the antenna cable: 17 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the antenna cable: 17 단계, 이미지 2개 중 2개
    • Slide one arm of a pair of angled tweezers under the metal neck of the black antenna cable's connector head on the USB‑C board.
    • Lift straight up to disconnect the cable.
  18. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket screws: 18 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket screws: 18 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
  19. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket: 19 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket: 19 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera bracket: 19 단계, 이미지 3개 중 3개
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
  20. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner front camera: 20 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner front camera: 20 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the inner front camera press connector.
  21. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera: 21 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera: 21 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner front camera: 21 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
  22. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the ultra wideband antenna: 22 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the ultra wideband antenna: 22 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the ultra wideband antenna: 22 단계, 이미지 3개 중 3개
    • Slide the flat end of a spudger under the ultra wideband antenna to separate the adhesive foam securing it to the frame.
    • Use tweezers, or your fingers, to lift the antenna off the frame to separate any remaining adhesive.
  23. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket screws: 23 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket screws: 23 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the ultra wideband bracket.
  24. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket: 24 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket: 24 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the ultra wideband bracket: 24 단계, 이미지 3개 중 3개
    • While holding the ultra wideband antenna out of the way, pull the bracket toward the bottom of the phone to release its clips.
    • Remove the ultra wideband bracket.
  25. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket screw: 25 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket screw: 25 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the interconnect cable bracket.
  26. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket: 26 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket: 26 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the bottom interconnect cable bracket: 26 단계, 이미지 3개 중 3개
    • Use tweezers, or your fingers, to pull the bracket toward the right edge of the phone to release its clip.
    • Remove the bottom interconnect cable bracket.
  27. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket screw: 27 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket screw: 27 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the inner display cable bracket.
  28. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket: 28 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the inner display cable bracket: 28 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to pull the inner display cable bracket towards the left edge of the phone to release it from its clip.
    • Remove the inner display cable bracket.
  29. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner display cable: 29 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner display cable: 29 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the inner display cable: 29 단계, 이미지 3개 중 3개
    • Insert the point of a spudger under the bottom left corner of the inner display press connector, next to the gold marker on the logic board.
    • Pry up and disconnect the inner display cable.
  30. Google Pixel 9 Pro Fold Loudspeaker Replacement: 30 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 30 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 30 단계, 이미지 3개 중 3개
    • Repeat the previous step to disconnect the top and bottom interconnect cable press connectors, making sure to only pry next to the gold markers.
  31. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the graphite sheet: 31 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the graphite sheet: 31 단계, 이미지 2개 중 2개
    • Peel the graphite sheet off the bottom speaker to separate the adhesive securing it.
  32. Google Pixel 9 Pro Fold Loudspeaker Replacement: 32 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 32 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 32 단계, 이미지 3개 중 3개
    • Continue peeling the graphite sheet off the logic board to separate the remaining adhesive.
  33. Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the side buttons: 33 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Disconnect the side buttons: 33 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to peel off the yellow tape on the side button cable ZIF connector.
    • Set the tape aside. You'll need it during reassembly.
  34. Google Pixel 9 Pro Fold Loudspeaker Replacement: 34 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 34 단계, 이미지 2개 중 2개
    • Use the point of a spudger, or your fingernail, to lift the locking tab on the side button cable ZIF connector.
  35. Google Pixel 9 Pro Fold Loudspeaker Replacement: 35 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 35 단계, 이미지 2개 중 2개
    • Use angled tweezers to pull the side button cable straight out of its slot.
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
  36. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the 5G mmWave antenna: 36 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the 5G mmWave antenna: 36 단계, 이미지 2개 중 2개
    • A thermal pad lightly adheres the 5G mmWave antenna to the frame.
    • Use the tip of a spudger to pry up the 5G mmWave antenna from the frame and separate it from the thermal pad.
  37. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board screws: 37 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board screws: 37 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the three screws securing the logic board:
    • One 2.2 mm‑long screw
    • Two 2.6 mm‑long screws
  38. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board: 38 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board: 38 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the logic board: 38 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger under the top left corner of the logic board, next to the inner front camera cutout.
    • You might feel some resistance since the logic board is bonded to the frame by thermal paste.
    • Pry up the logic board enough so you can grip the top edge with your fingers.
  39. Google Pixel 9 Pro Fold Loudspeaker Replacement: 39 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 39 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 39 단계, 이미지 3개 중 3개
    • Lift the top of the logic board out of the frame and remove it.
    • Lay down the logic board upside down on a clean surface.
  40. Google Pixel 9 Pro Fold Loudspeaker Replacement, Clean the thermal paste: 40 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Clean the thermal paste: 40 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Clean the thermal paste: 40 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
  41. Google Pixel 9 Pro Fold Loudspeaker Replacement: 41 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 41 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 41 단계, 이미지 3개 중 3개
    • Don't press down heavily on the logic board while cleaning it to prevent bending the metal springs or smudging the rear camera assembly.
    • Repeat the thermal paste cleaning procedure for the bottom of the logic board.
  42. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the conductive fabric: 42 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the conductive fabric: 42 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the conductive fabric: 42 단계, 이미지 3개 중 3개
    • Use tweezers, or your fingers, to peel the section of conductive fabric connecting the loudspeaker to the frame.
  43. Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the cable adhesive: 43 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the cable adhesive: 43 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Separate the cable adhesive: 43 단계, 이미지 3개 중 3개
    • Slide one arm of a pair of angled tweezers under the contact pad connected to the loudspeaker.
    • Lift the contact pad to separate the adhesive securing it to the frame.
  44. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker screw: 44 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker screw: 44 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to remove the 2.6 mm‑long screw securing the loudspeaker.
  45. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker: 45 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the loudspeaker: 45 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up the left edge of the loudspeaker to separate the adhesive securing it to the frame.
  46. Google Pixel 9 Pro Fold Loudspeaker Replacement: 46 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 46 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 46 단계, 이미지 3개 중 3개
    • Use your fingers to lift the top edge of the loudspeaker and pull it out of its recess in the frame.
    • Remove the loudspeaker.
  47. Google Pixel 9 Pro Fold Loudspeaker Replacement, End of disassembly: 47 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  48. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 48 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 48 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 48 단계, 이미지 3개 중 3개
    • The next six steps show how to replace the conductive fabric on the bottom of your loudspeaker and the adhesive on the loudspeaker's cable. Skip these steps if your fabric and adhesive are intact.
    • Use tweezers, or your fingers, to remove the bottom and top conductive fabrics or the loudspeaker cable adhesive if they're not intact.
  49. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the bottom conductive fabric: 49 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the bottom conductive fabric: 49 단계, 이미지 2개 중 2개
    • Align the bottom loudspeaker conductive fabric on the underside of the loudspeaker.
    • Refer to the second photo for the correct orientation.
  50. Google Pixel 9 Pro Fold Loudspeaker Replacement: 50 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 50 단계, 이미지 2개 중 2개
    • Remove the conductive fabric from its clear and colored liners and lay it over its spot on the loudspeaker.
  51. Google Pixel 9 Pro Fold Loudspeaker Replacement: 51 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 51 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the loudspeaker.
  52. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the adhesive: 52 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the adhesive: 52 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the adhesive: 52 단계, 이미지 3개 중 3개
    • Peel the clear liner off the loudspeaker cable adhesive.
    • Align the adhesive over the loudspeaker cable and lay it down, making sure not to cover the hole in the cable.
  53. Google Pixel 9 Pro Fold Loudspeaker Replacement: 53 단계, 이미지 1개 중 1개
    • Use your fingers to lightly pinch the cable and adhere the adhesive strip.
    • Remove the blue liner from the adhesive strip.
  54. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the loudspeaker: 54 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the loudspeaker: 54 단계, 이미지 2개 중 2개
    • Align the hole in the loudspeaker cable over its peg on the frame.
    • Press down the cable with the tip of a spudger, or your finger, to adhere it to the frame.
  55. Google Pixel 9 Pro Fold Loudspeaker Replacement: 55 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 55 단계, 이미지 2개 중 2개
    • While pressing the cable down, reinsert the loudspeaker at an angle into its recess and press it flat to the frame.
  56. Google Pixel 9 Pro Fold Loudspeaker Replacement: 56 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 56 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 56 단계, 이미지 3개 중 3개
    • While holding the loudspeaker in place, use a Torx Plus 3IP driver to install the 2.6 mm‑long screw securing the loudspeaker.
  57. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the top conductive fabric: 57 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the top conductive fabric: 57 단계, 이미지 2개 중 2개
    • The next four steps show how to replace the conductive fabric on the top of the loudspeaker. Skip these steps if your fabric is still intact.
    • Peel off the clear liner on the top loudspeaker conductive fabric.
    • Peel off the small colored liner covering the rounded corner of the fabric.
  58. Google Pixel 9 Pro Fold Loudspeaker Replacement: 58 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 58 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 58 단계, 이미지 3개 중 3개
    • Align the rounded corner of the conductive fabric with the same‑shaped marking on the frame.
    • Lay the fabric down onto the frame and the loudspeaker.
  59. Google Pixel 9 Pro Fold Loudspeaker Replacement: 59 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 59 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 59 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the frame and loudspeaker.
  60. Google Pixel 9 Pro Fold Loudspeaker Replacement: 60 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 60 단계, 이미지 2개 중 2개
    • Peel off the large colored liner from the conductive fabric.
  61. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply new thermal paste: 61 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply new thermal paste: 61 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply new thermal paste: 61 단계, 이미지 3개 중 3개
    • Apply small beads of thermal paste (five total) to the motherboard in the same locations as the old thermal paste.
  62. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the logic board: 62 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the logic board: 62 단계, 이미지 2개 중 2개
    • Place the logic board back into its cutout in the frame, making sure no cables get trapped underneath it.
  63. Google Pixel 9 Pro Fold Loudspeaker Replacement: 63 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 63 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the three screws securing the logic board:
  64. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the side button cable: 64 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the side button cable: 64 단계, 이미지 2개 중 2개
    • Use angled tweezers to push the side button cable back into its slot.
  65. Google Pixel 9 Pro Fold Loudspeaker Replacement: 65 단계, 이미지 1개 중 1개
    • Flip the locking tab down and lightly press on it until it clicks into place.
  66. Google Pixel 9 Pro Fold Loudspeaker Replacement: 66 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 66 단계, 이미지 2개 중 2개
    • Place the yellow tape over the ZIF connector and its cable.
  67. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new graphite sheet: 67 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new graphite sheet: 67 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new graphite sheet: 67 단계, 이미지 3개 중 3개
    • Peel the clear liner off your replacement graphite sheet to expose the adhesive on the upper half.
    • Align the upper half of the graphite sheet over the logic board and lay it down.
  68. Google Pixel 9 Pro Fold Loudspeaker Replacement: 68 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 68 단계, 이미지 2개 중 2개
    • Use your finger to press down the upper half of the graphite sheet and secure it to the logic board.
  69. Google Pixel 9 Pro Fold Loudspeaker Replacement: 69 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 69 단계, 이미지 2개 중 2개
    • Remove the blue liner from the bottom of the graphite sheet to expose the adhesive underneath.
  70. Google Pixel 9 Pro Fold Loudspeaker Replacement: 70 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 70 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 70 단계, 이미지 3개 중 3개
    • Drag your finger from the middle section of the graphite sheet to the adhesive spot on the loudspeaker to flatten the graphite sheet and adhere it.
  71. Google Pixel 9 Pro Fold Loudspeaker Replacement: 71 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 71 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 71 단계, 이미지 3개 중 3개
    • Grip the pull tab at the top of the graphite sheet and peel off the remaining liner.
  72. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the right side cables: 72 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the right side cables: 72 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the right side cables: 72 단계, 이미지 3개 중 3개
    • Reconnect the inner display cable and the top and bottom interconnect cable press connectors.
  73. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner display cable bracket: 73 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner display cable bracket: 73 단계, 이미지 2개 중 2개
    • Reinsert the inner display cable bracket clip under its slot in the logic board and align the screw holes.
  74. Google Pixel 9 Pro Fold Loudspeaker Replacement: 74 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 74 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the inner display cable bracket.
  75. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the bottom interconnect cable bracket: 75 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the bottom interconnect cable bracket: 75 단계, 이미지 2개 중 2개
    • Reinsert the bottom interconnect bracket clip under its slot in the frame and align the screw hole.
  76. Google Pixel 9 Pro Fold Loudspeaker Replacement: 76 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 76 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the interconnect cable bracket.
  77. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the ultra wideband bracket: 77 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the ultra wideband bracket: 77 단계, 이미지 2개 중 2개
    • While holding the ultra wideband antenna out of the way, reinsert the ultra wideband bracket clip under its slot in the frame and align the screw holes.
  78. Google Pixel 9 Pro Fold Loudspeaker Replacement: 78 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 78 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the ultra wideband bracket.
  79. Google Pixel 9 Pro Fold Loudspeaker Replacement, Replace the ultra wideband bracket adhesive: 79 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Replace the ultra wideband bracket adhesive: 79 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Replace the ultra wideband bracket adhesive: 79 단계, 이미지 3개 중 3개
    • If the adhesive on your ultra wideband bracket is still sticky, skip this step.
    • Remove the old adhesive and foam on the ultra wideband bracket and under the antenna.
    • Replace the corresponding adhesive and foam to the bracket and the frame.
    • Press the ultra wideband antenna to the frame and re‑adhere it.
  80. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 80 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 80 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 80 단계, 이미지 3개 중 3개
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
  81. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: 81 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: 81 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: 81 단계, 이미지 3개 중 3개
    • Peel the replacement inner front camera adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
  82. Google Pixel 9 Pro Fold Loudspeaker Replacement: 82 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 82 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 82 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
  83. Google Pixel 9 Pro Fold Loudspeaker Replacement: 83 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 83 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 83 단계, 이미지 3개 중 3개
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
  84. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera: 84 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera: 84 단계, 이미지 2개 중 2개
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
  85. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera bracket: 85 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera bracket: 85 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the inner front camera bracket: 85 단계, 이미지 3개 중 3개
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
  86. Google Pixel 9 Pro Fold Loudspeaker Replacement: 86 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 86 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
  87. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the antenna cable: 87 단계, 이미지 1개 중 1개
    • Use tweezers to hold the antenna cable's connector in place over its socket and gently press down with your finger or a spudger until the connector snaps into place.
  88. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the vibrator bracket: 88 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the vibrator bracket: 88 단계, 이미지 2개 중 2개
    • Place the vibrator bracket on the logic board and align its screw holes.
  89. Google Pixel 9 Pro Fold Loudspeaker Replacement: 89 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 89 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the vibrator bracket.
  90. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the USB-C port board cable: 90 단계, 이미지 1개 중 1개
    • Reconnect the USB-C port board cable press connector.
  91. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the base battery: 91 단계, 이미지 1개 중 1개
    • Reconnect the base battery press connector.
  92. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the base battery bracket: 92 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the base battery bracket: 92 단계, 이미지 2개 중 2개
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
  93. Google Pixel 9 Pro Fold Loudspeaker Replacement: 93 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 93 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
  94. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 94 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the old adhesive: 94 단계, 이미지 2개 중 2개
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  95. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover liners: 95 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover liners: 95 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the back cover liners: 95 단계, 이미지 3개 중 3개
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  96. Google Pixel 9 Pro Fold Loudspeaker Replacement: 96 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 96 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 96 단계, 이미지 3개 중 3개
    • Peel off the remaining clear liners on the outside of the back cover.
  97. Google Pixel 9 Pro Fold Loudspeaker Replacement, Compare your adhesive: 97 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Compare your adhesive: 97 단계, 이미지 2개 중 2개
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
  98. Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: 98 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: 98 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Apply the new adhesive: 98 단계, 이미지 3개 중 3개
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  99. Google Pixel 9 Pro Fold Loudspeaker Replacement: 99 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 99 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  100. Google Pixel 9 Pro Fold Loudspeaker Replacement: 100 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 100 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 100 단계, 이미지 3개 중 3개
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  101. Google Pixel 9 Pro Fold Loudspeaker Replacement: 101 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 101 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 101 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  102. Google Pixel 9 Pro Fold Loudspeaker Replacement: 102 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 102 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 102 단계, 이미지 3개 중 3개
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  103. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reconnect the back cover cable: 103 단계, 이미지 1개 중 1개
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  104. Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the top bracket: 104 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Reinstall the top bracket: 104 단계, 이미지 2개 중 2개
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  105. Google Pixel 9 Pro Fold Loudspeaker Replacement: 105 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 105 단계, 이미지 2개 중 2개
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  106. Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the secondary liner: 106 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Remove the secondary liner: 106 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  107. Google Pixel 9 Pro Fold Loudspeaker Replacement: 107 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 107 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 107 단계, 이미지 3개 중 3개
    • Peel off the secondary liner to expose the adhesive.
  108. Google Pixel 9 Pro Fold Loudspeaker Replacement, Secure the back cover: 108 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement, Secure the back cover: 108 단계, 이미지 2개 중 2개
    • Align the top edge of the back cover with the frame and press down to adhere it.
  109. Google Pixel 9 Pro Fold Loudspeaker Replacement: 109 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 109 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Fold Loudspeaker Replacement: 109 단계, 이미지 3개 중 3개
    • Press along the perimeter of the back cover to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
결론
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,557 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 38
전체 시간: 638
