주요 콘텐츠로 건너뛰기
Google Pixel 9 Pro Rear Cover Replacement
필요한 것
  1. Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: 1 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: 1 단계, 이미지 2개 중 2개
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: 2 단계, 이미지 3개 중 3개
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 2개
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro Rear Cover Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement: 6 단계, 이미지 3개 중 3개
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro Rear Cover Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 3개
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: 9 단계, 이미지 2개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
  10. Google Pixel 9 Pro Rear Cover Replacement: 10 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement: 10 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement: 10 단계, 이미지 3개 중 3개
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
  11. Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 1개 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 2개 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
  12. Google Pixel 9 Pro Rear Cover Replacement, Remove the rear cover: 12 단계, 이미지 1개 중 1개
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
결론
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,052 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,603개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 74
지난 30일: 329
전체 시간: 5,288
