주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 9 Pro XL Wireless Charging Assembly Replacement
조회수: 1.7천
통계 보기:
지난 24시간
6
지난 7일:
40
지난 30일:
139
전체 시간:
1,747
댓글: 5
5 comments on steps.
완료함: 0
이 가이드를 "완료"로 표시한 사람은 아직 없습니다. 첫 번째 주인공이 되시겠어요?
즐겨찾기: 0
해당 안내서에 좋아요를 누르고 구독한 사람이 아직 없습니다. 첫 번째 주인공이 되시겠습니까?
소요 시간: 1 - 2 시간
난이도: 조정
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the wireless charging assembly in your Google Pixel 9 Pro XL.
If your phone's wireless charging is intermittent or not charging at all, it may be time to replace the wireless charging assembly.
You'll need replacement rear cover adhesive to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
필요한 것
도구
    1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Safety precautions: 1 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Safety precautions: 1 단계, 이미지 2개 중 2개
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      댓글 쓰기
    1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: 2 단계, 이미지 3개 중 3개
      • Adhesive secures the perimeter of the rear cover to the frame.
      • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
      • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
      댓글 쓰기
    2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 2개
      • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
      댓글 쓰기
    3. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
      • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
      • Insert the tip of an opening pick in the gap.
      댓글 쓰기
    4. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: 5 단계, 이미지 3개 중 3개
      • Slide your opening pick along the bottom edge to separate the adhesive securing it.
      • Remember: don't insert the opening pick deeper than 3 mm.
      댓글 쓰기
    5. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 6 단계, 이미지 3개 중 3개
      • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
      댓글 쓰기
    6. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 7 단계, 이미지 3개 중 3개
      • Slide your pick down the right edge to separate the remaining adhesive.
      댓글 쓰기
    1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: 8 단계, 이미지 3개 중 3개
      • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
      • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
      • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
      • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
      댓글 쓰기
    2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 9 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 9 단계, 이미지 2개 중 2개
      • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
      댓글 쓰기
    3. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 10 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • Use tweezers or your fingers to remove the cable cover.
      댓글 쓰기
    4. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: 11 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect the rear cover press connector.
      댓글 쓰기
    5. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the rear cover: 12 단계, 이미지 1개 중 1개
      • Remove the rear cover.
      • During reassembly, follow this guide to apply new adhesive and install your back cover.
      댓글 쓰기
    1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: 13 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: 13 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: 13 단계, 이미지 3개 중 3개
      • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
      • You can completely remove the tape if you want, but be sure to keep it for reassembly.
      댓글 쓰기
    2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 14 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 14 단계, 이미지 2개 중 2개
      • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
      댓글 쓰기
    3. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 15 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 15 단계, 이미지 2개 중 2개
      • Use tweezers or your fingers to remove the cover.
      댓글 쓰기
    4. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the wireless charging assembly: 16 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the wireless charging assembly: 16 단계, 이미지 2개 중 2개
      • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
      댓글 쓰기
    5. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 17 단계, 이미지 3개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 17 단계, 이미지 3개 중 2개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 17 단계, 이미지 3개 중 3개
      • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
      댓글 쓰기
    6. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: 18 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: 18 단계, 이미지 2개 중 2개
      • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
      댓글 쓰기
    7. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly: 19 단계, 이미지 2개 중 1개 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly: 19 단계, 이미지 2개 중 2개
      • Remove the wireless charging assembly.
      댓글 쓰기
결론
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
207,230 평판
안내서 1,266개를 작성함
팀
iFixit iFixit 회원
Staff
121 회원들
안내서 72,907개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 40
지난 30일: 139
전체 시간: 1,747
