주요 콘텐츠로 건너뛰기
Google Pixelbook Go Battery Replacement
필요한 것
  1. Google Pixelbook Go Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Google Pixelbook Go Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Battery Replacement: 2 단계, 이미지 1/2 Google Pixelbook Go Battery Replacement: 2 단계, 이미지 2/2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Battery Replacement: 3 단계, 이미지 1/3 Google Pixelbook Go Battery Replacement: 3 단계, 이미지 2/3 Google Pixelbook Go Battery Replacement: 3 단계, 이미지 3/3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Battery Replacement: 4 단계, 이미지 1/1
    • Insert wisdom here.
  5. Google Pixelbook Go Battery Replacement, Battery: 5 단계, 이미지 1/1
    • If your replacement battery comes with a new cover already attached, disregard this step.
    • Use an iFixit opening tool to peel back the adhesive on the entire battery system.
    • Carefully remove battery from the base.
    • Align the new battery system with the cover and attach using adhesive or double-sided tape.
결론
Caroline Gilliard
회원 가입일: 03/01/23
81 평판
안내서 1개 작성함
University of Delaware, Team 11-1, McGuire Spring 2023 University of Delaware, Team 11-1, McGuire Spring 2023 회원
UD-MCGUIRE-S23S11G1
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 164
전체 시간: 2,142
