주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GravityLight Motor Replacement
필요한 것
  1. GravityLight Motor Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 1개 GravityLight Motor Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 2개
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Motor Replacement, Opening the Device Housing: 2 단계, 이미지 1개 중 1개
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Motor Replacement, Isolating the Back Panel: 3 단계, 이미지 1개 중 1개
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Motor Replacement, Removing the Back Panel Screws: 4 단계, 이미지 1개 중 1개
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Motor Replacement, Removing the LED Housing: 5 단계, 이미지 1개 중 1개
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Motor Replacement, Removing White Frame and Gear: 6 단계, 이미지 1개 중 1개
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Motor Replacement, Removing the Motor Screws: 7 단계, 이미지 1개 중 1개
    • Remove the two 2cm Phillips 00 screws from the motor housing.
    • The spring pushing the motor housing may pop out once the motor has been removed.
  8. GravityLight Motor Replacement, Separating the Back Panel Housing: 8 단계, 이미지 3개 중 1개 GravityLight Motor Replacement, Separating the Back Panel Housing: 8 단계, 이미지 3개 중 2개 GravityLight Motor Replacement, Separating the Back Panel Housing: 8 단계, 이미지 3개 중 3개
    • Firmly grasp both parts of the back panel and pull them apart.
  9. GravityLight Motor Replacement, Removing the Motor: 9 단계, 이미지 3개 중 1개 GravityLight Motor Replacement, Removing the Motor: 9 단계, 이미지 3개 중 2개 GravityLight Motor Replacement, Removing the Motor: 9 단계, 이미지 3개 중 3개
    • Place the middle section flat with the side that holds the gear system down and locate the back of the motor.
    • Clip the wires close to the soldered joints.
    • Lift the motor out of the middle section. Using the flush wire cutters, clip the red and the blue wires located on the motor's back.
  10. GravityLight Motor Replacement, Soldering the New Motor: 10 단계, 이미지 1개 중 1개
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Anthony Jungquist
회원 가입일: 09/26/14
125 평판
안내서 1개를 작성함
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 회원
CPSU-FORTE-F14S12G2
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 49
전체 시간: 2,497
