주요 콘텐츠로 건너뛰기
HP 15-ay052nr Hard Disk Drive Replacement
필요한 것
  1. HP 15-ay052nr Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1/1
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr Hard Disk Drive Replacement: 2 단계, 이미지 1/1
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr Hard Disk Drive Replacement: 3 단계, 이미지 1/1
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr Hard Disk Drive Replacement, Bottom Cover: 4 단계, 이미지 1/1
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr Hard Disk Drive Replacement: 5 단계, 이미지 1/1
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr Hard Disk Drive Replacement: 6 단계, 이미지 1/1
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr Hard Disk Drive Replacement: 7 단계, 이미지 1/1
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr Hard Disk Drive Replacement, Hard Disk Drive: 8 단계, 이미지 1/1
    • Remove the three 3 mm screws that mount the hard drive to the computer.
  9. HP 15-ay052nr Hard Disk Drive Replacement: 9 단계, 이미지 1/1
    • Remove the connector from the hard drive by pulling it away from the drive.
  10. HP 15-ay052nr Hard Disk Drive Replacement: 10 단계, 이미지 1/2 HP 15-ay052nr Hard Disk Drive Replacement: 10 단계, 이미지 2/2
    • Lift the hard drive from the computer and remove the two 3-mm screws that connect each mounting bracket to the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gabriel Zeller
회원 가입일: 01/11/19
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 1,360
