주요 콘텐츠로 건너뛰기
HP 15-ay078nr Back Panel Replacement
필요한 것
  1. HP 15-ay078nr Back Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr Back Panel Replacement: 2 단계, 이미지 1/2 HP 15-ay078nr Back Panel Replacement: 2 단계, 이미지 2/2
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr Back Panel Replacement: 3 단계, 이미지 1/2 HP 15-ay078nr Back Panel Replacement: 3 단계, 이미지 2/2
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
  4. HP 15-ay078nr Back Panel Replacement, Back Panel: 4 단계, 이미지 1/2 HP 15-ay078nr Back Panel Replacement, Back Panel: 4 단계, 이미지 2/2
    • Pull off the two rubber feet on the underside of the device.
    • Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
  5. HP 15-ay078nr Back Panel Replacement: 5 단계, 이미지 1/1
    • Slide an opening pick around the edges between the back panel and the rest of the device to release the plastic retention clips that hold the panel in place.
  6. HP 15-ay078nr Back Panel Replacement: 6 단계, 이미지 1/1
    • Lift up on the panel to remove it completely from the device.
결론
Bryce Getchell
회원 가입일: 10/25/21
315 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 176
