주요 콘텐츠로 건너뛰기
HP 15-ay078nr Screen Replacement
필요한 것
  1. HP 15-ay078nr Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Open the lid of the laptop.
    • Feel the top of the laptop screen to find a ridge separating the front and back of the screen bezel.
    • Using an opening pick tool, gently pry the front screen bezel apart from the rear to release the internal plastic retention clips.
    • You may see small bits of plastic come loose from the screen bezel. This is not an issue and will not hurt the reassembly process.
  2. HP 15-ay078nr Screen Replacement: 2 단계, 이미지 1/2 HP 15-ay078nr Screen Replacement: 2 단계, 이미지 2/2
    • Remove the four 3.2 mm screws from the screen using a Phillips #2 screwdriver.
  3. HP 15-ay078nr Screen Replacement: 3 단계, 이미지 1/3 HP 15-ay078nr Screen Replacement: 3 단계, 이미지 2/3 HP 15-ay078nr Screen Replacement: 3 단계, 이미지 3/3
    • Gently lay the screen against the keyboard.
    • Disconnect the display cable from the rest of the laptop.
결론
Power on your device to see the new screen. If the backlight is flickering, the LCD cable may have not been pushed in completely. Ensure it is fully connected.
Liberty DeAngelo
회원 가입일: 10/25/21
97 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 188
