주요 콘텐츠로 건너뛰기
HP 15-ay114cy Battery Replacement
  1. HP 15-ay114cy Battery Replacement, Orient the Laptop: 1 단계, 이미지 1/1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Battery Replacement, Push out the Battery: 2 단계, 이미지 1/2 HP 15-ay114cy Battery Replacement, Push out the Battery: 2 단계, 이미지 2/2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Battery Replacement, Remove the Battery: 3 단계, 이미지 1/2 HP 15-ay114cy Battery Replacement, Remove the Battery: 3 단계, 이미지 2/2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
결론
Michael Falanga
회원 가입일: 01/24/20
347 평판
안내서 1개 작성함
S20S3G#1 S20S3G#1 회원
Local Repair Groups
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 309
