주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-ay114cy Fan Replacement
필요한 것
  1. HP 15-ay114cy Fan Replacement, Orient the Laptop: 1 단계, 이미지 1개 중 1개
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Fan Replacement, Push out the Battery: 2 단계, 이미지 2개 중 1개 HP 15-ay114cy Fan Replacement, Push out the Battery: 2 단계, 이미지 2개 중 2개
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Fan Replacement, Remove the Battery: 3 단계, 이미지 2개 중 1개 HP 15-ay114cy Fan Replacement, Remove the Battery: 3 단계, 이미지 2개 중 2개
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Fan Replacement, Unscrew the Back Cover: 4 단계, 이미지 2개 중 1개 HP 15-ay114cy Fan Replacement, Unscrew the Back Cover: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the twelve 8 mm Phillips screws that are holding down the bottom cover of the laptop.
  5. HP 15-ay114cy Fan Replacement, Remove the Disk Drive: 5 단계, 이미지 2개 중 1개 HP 15-ay114cy Fan Replacement, Remove the Disk Drive: 5 단계, 이미지 2개 중 2개
    • Grab a hold of the disk drive and carefully pull it away from the computer.
    • Continue to slide the disk drive out of the laptop until fully removed.
    • Due to the removal of the battery, no power is available to open the disk drive through the use of the eject button.
    • Make sure to pull out the disk drive at a 90 degree angle as demonstrated. Do not attempt to wiggle the drive out of the laptop.
    • There will be resistance when removing the drive. Mishandling may cause broken wires, which could make your disk drive inoperative.
  6. HP 15-ay114cy Fan Replacement, Remove the Back Cover: 6 단계, 이미지 3개 중 1개 HP 15-ay114cy Fan Replacement, Remove the Back Cover: 6 단계, 이미지 3개 중 2개 HP 15-ay114cy Fan Replacement, Remove the Back Cover: 6 단계, 이미지 3개 중 3개
    • Place a plastic opening tool in-between the upper and lower pieces of the bottom cover.
    • Using your hands and the plastic opening tool, gently separate the cover from the frame.
    • Slowly remove the bottom cover from the base of the laptop.
    • Using metal pry tools can damage your device.
  7. HP 15-ay114cy Fan Replacement, Remove the Fan Screws: 7 단계, 이미지 2개 중 1개 HP 15-ay114cy Fan Replacement, Remove the Fan Screws: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the two 8 mm Phillips-head screws that attach the fan to the base.
  8. HP 15-ay114cy Fan Replacement, Remove the Fan Wire: 8 단계, 이미지 3개 중 1개 HP 15-ay114cy Fan Replacement, Remove the Fan Wire: 8 단계, 이미지 3개 중 2개 HP 15-ay114cy Fan Replacement, Remove the Fan Wire: 8 단계, 이미지 3개 중 3개
    • Using your index finger and thumb, carefully grab the wire that connects the fan to the motherboard.
    • Using a bit of force, remove the cable from the connector on the motherboard.
  9. HP 15-ay114cy Fan Replacement, Remove the Fan: 9 단계, 이미지 2개 중 1개 HP 15-ay114cy Fan Replacement, Remove the Fan: 9 단계, 이미지 2개 중 2개
    • Using your hand, grab one of the fan corners and pull up.
    • Carefully remove the entire fan from the base of the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bradley Evans
회원 가입일: 01/24/20
622 평판
안내서 5개를 작성함
S20S3G#1 S20S3G#1 회원
Local Repair Groups
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 69
전체 시간: 1,220
