주요 콘텐츠로 건너뛰기
HP 15-bs168cl Hard Drive Replacement
필요한 것
  1. HP 15-bs168cl Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP 15-bs168cl Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug your laptop from its power adapter.
    • Turn the laptop over.
  2. HP 15-bs168cl Hard Drive Replacement: 2 단계, 이미지 1/2 HP 15-bs168cl Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
  3. HP 15-bs168cl Hard Drive Replacement: 3 단계, 이미지 1/2 HP 15-bs168cl Hard Drive Replacement: 3 단계, 이미지 2/2
    • Slide the Battery release slider towards the battery while pulling the battery out.
  4. HP 15-bs168cl Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 HP 15-bs168cl Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
  5. HP 15-bs168cl Hard Drive Replacement: 5 단계, 이미지 1/2 HP 15-bs168cl Hard Drive Replacement: 5 단계, 이미지 2/2
    • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
    • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
  6. HP 15-bs168cl Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the DVD drive by carefully sliding it out.
  7. HP 15-bs168cl Hard Drive Replacement: 7 단계, 이미지 1/3 HP 15-bs168cl Hard Drive Replacement: 7 단계, 이미지 2/3 HP 15-bs168cl Hard Drive Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Flip the laptop over and open the screen.
    • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
    • Flip the computer back over and remove the bottom plastic shell.
  8. HP 15-bs168cl Hard Drive Replacement: 8 단계, 이미지 1/3 HP 15-bs168cl Hard Drive Replacement: 8 단계, 이미지 2/3 HP 15-bs168cl Hard Drive Replacement: 8 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two 3.4 mm screws on the sides.
    • Use a Phillips #0 screwdriver to remove the one 3.3 mm screw at the bottom of the bracket.
  9. HP 15-bs168cl Hard Drive Replacement: 9 단계, 이미지 1/2 HP 15-bs168cl Hard Drive Replacement: 9 단계, 이미지 2/2
    • Remove the metal bracket holding the hard drive in place.
    • Carefully lift up the hard drive and slide it out of its connector.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Ian Gascon
회원 가입일: 10/15/19
792 평판
안내서 4개 작성하였습니다
UC Santa Barbara, Team S3-G3, Nowak Fall 2019 UC Santa Barbara, Team S3-G3, Nowak Fall 2019 회원
UCSB-NOWAK-F19S3G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thanks, I would have missed the screws under the rubber feet!
Kenneth Dalton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 25
전체 시간: 1,503
