소개
If your laptop screen begins to fail by displaying distorted images or coloring, being pixelated, displaying resolution lines, having broken plastic, or black splotches on the display, use this guide to remove and replace your screen. To troubleshoot screen problem, refer to the guide here.
필요한 것
이 단계에 사용된 도구:Plastic Cards$2.99
Open the device so the screen is facing out.
Slide a thin plastic card into the space between the screen and the bezel. Slide the card around the entire screen to detach the case.
다른 2명이 해당 안내서를 완성하였습니다.
