소개
If the HP 15-da0002dx is not charging correctly or only works when plugged in, follow these to replace the battery.
The battery powers the computer and allows it to be used without a power cord. A faulty battery can lead to improper charging and low battery life. Before replacing the battery, make sure your computer’s software is up to date by visiting the latest Official Hp Website. Also be sure to check if the power adapter being used is the correct power adaptor for your computer. Visit the HP-da0002dx troubleshooting page for more information on software and power adaptor solutions.
Before using this guide, power off the computer and wait for the components to cool. Working over a non-carpeted surface will reduce the risk of ESD damage (electrostatic discharge). A non-carpeted surface should not be able to conduct electricity and is connected to a grounded surface. Another way to reduce the risk of ESD damage is by using a plastic tool when removing the battery as plastic does not conduct electricity.
필요한 것
다른 3명이 해당 안내서를 완성하였습니다.
