주요 콘텐츠로 건너뛰기
HP 15-f004dx Optical Drive Replacement
필요한 것
  1. HP 15-f004dx Optical Drive  Replacement, Battery: 1 단계, 이미지 1/1
    • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
  2. HP 15-f004dx Optical Drive  Replacement: 2 단계, 이미지 1/2 HP 15-f004dx Optical Drive  Replacement: 2 단계, 이미지 2/2
    • Locate a switch in the upper left corner with a lock symbol next to it.
    • Slide the switch to the right until you see an unlocked symbol on the opposite side.
  3. HP 15-f004dx Optical Drive  Replacement: 3 단계, 이미지 1/2 HP 15-f004dx Optical Drive  Replacement: 3 단계, 이미지 2/2
    • There is another switch on the opposite side of the computer with a battery symbol next to it.
    • Slide this switch to the left and the battery should detach from the computer.
    • To completely remove the battery, simply pull the battery away from the computer.
  4. HP 15-f004dx Optical Drive  Replacement, Optical Drive: 4 단계, 이미지 1/2 HP 15-f004dx Optical Drive  Replacement, Optical Drive: 4 단계, 이미지 2/2
    • Use a J1 or PH1 screwdriver to remove the 6.5mm screw that secures the optical drive.
  5. HP 15-f004dx Optical Drive  Replacement: 5 단계, 이미지 1/1
    • Once the optical drive screw has been removed, use a plastic opening tool to loosen the optical drive.
    • If the battery port is facing away from you, the optical drive will be on the left hand side of the device.
  6. HP 15-f004dx Optical Drive  Replacement: 6 단계, 이미지 1/1
    • Gently remove the optical drive once it has been loosened.
결론
Dylan Kahle
회원 가입일: 09/07/18
351 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 341
