주요 콘텐츠로 건너뛰기
HP 15-f004dx RAM Replacement
필요한 것
  1. HP 15-f004dx RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Flip laptop over to the back, so that the stickers are showing and the RAM panel is facing up.
  2. HP 15-f004dx RAM Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to unscrew the two 2mm RAM shield screws from the bottom of the laptop.
  3. HP 15-f004dx RAM Replacement: 3 단계, 이미지 1/3 HP 15-f004dx RAM Replacement: 3 단계, 이미지 2/3 HP 15-f004dx RAM Replacement: 3 단계, 이미지 3/3
    • Remove the RAM shield.
    • Small brackets secure the RAM. Push the brackets to the side to free the RAM.
  4. HP 15-f004dx RAM Replacement: 4 단계, 이미지 1/2 HP 15-f004dx RAM Replacement: 4 단계, 이미지 2/2
    • The RAM card should now pop up out of its slot. Remove the RAM.
    • Next, you will replace/reseat the memory modules following steps 3 and 4 in reverse. Once you have completed that, you can now power on the computer to test and see if reseating/replacing the RAM has resolved the problem.
결론
Dylan Kahle
회원 가입일: 09/07/18
351 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 723
