주요 콘텐츠로 건너뛰기
HP 15-g029wm Battery Replacement
  1. HP 15-g029wm Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Battery Replacement: 2 단계, 이미지 1/1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Battery Replacement: 3 단계, 이미지 1/3 HP 15-g029wm Battery Replacement: 3 단계, 이미지 2/3 HP 15-g029wm Battery Replacement: 3 단계, 이미지 3/3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Battery Replacement: 4 단계, 이미지 1/3 HP 15-g029wm Battery Replacement: 4 단계, 이미지 2/3 HP 15-g029wm Battery Replacement: 4 단계, 이미지 3/3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Syrinity/Ezyra/Ezra
회원 가입일: 01/29/24
375 평판
안내서 3개 작성하였습니다
Austin Community College, Team 18-2, Watkins Spring 2024 Austin Community College, Team 18-2, Watkins Spring 2024 회원
AUSTINCC-WATKINS-S24S18G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 120
