주요 콘텐츠로 건너뛰기
HP 17-x173dx Optical Disk Drive Replacement
필요한 것
  1. HP 17-x173dx Optical Disk Drive Replacement, Optical Disk Drive: 1 단계, 이미지 1/1
    • Start by placing the laptop with its bottom facing up.
    • Using the Phillips #0 screwdriver, remove the single 7 mm screw that holds the disk drive in place.
  2. HP 17-x173dx Optical Disk Drive Replacement: 2 단계, 이미지 1/2 HP 17-x173dx Optical Disk Drive Replacement: 2 단계, 이미지 2/2
    • Use a spudger or thin item to apply outward pressure between the disk drive opening and the device to remove the optical disk drive. You may be able to remove it using your fingernail.
결론
Insert new optical drive. To reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Guggenheim
회원 가입일: 09/16/19
159 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 233
