소개
This guide is for removing and replacing the Optical Disk Drive. The main symptom for a bad disk drive is if your computer is having issues reading disks. Check this troubleshooting topic first before replacing your disk drive.
필요한 것
Start by placing the laptop with its bottom facing up.
Using the Phillips #0 screwdriver, remove the single 7 mm screw that holds the disk drive in place.
Insert new optical drive. To reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
