주요 콘텐츠로 건너뛰기
HP Chromebook 11 G6 EE Webcam Camera Module Replacement
필요한 것
  1. HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Keyboard: 1 단계, 이미지 1/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Keyboard: 1 단계, 이미지 2/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Keyboard: 1 단계, 이미지 3/3
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 2 단계, 이미지 1/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 2 단계, 이미지 2/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 2 단계, 이미지 3/3
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 3 단계, 이미지 1/2 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 3 단계, 이미지 2/2
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
  4. HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Webcam Camera Module: 4 단계, 이미지 1/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Webcam Camera Module: 4 단계, 이미지 2/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement, Webcam Camera Module: 4 단계, 이미지 3/3
    • Use the opening pick around the edges of the screen bezel carefully to remove.
    • Remove screen bezel.
  5. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 5 단계, 이미지 1/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 5 단계, 이미지 2/3 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 5 단계, 이미지 3/3
    • Peel back the tape that secures the webcam to the left display panel hinge.
    • Gently slide out the webcam connector.
  6. HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 6 단계, 이미지 1/2 HP Chromebook 11 G6 EE Webcam Camera Module Replacement: 6 단계, 이미지 2/2
    • Place the iFixit opening tool under the webcam module.
    • This is will probably bend the metal due to the strong adhesive in place.
    • Using the iFixit tool work the tool around the top edge of the webcam module to loosen the module.
    • Use your fingers to lift the webcam module out of its setting.
결론
Israel Barnes
회원 가입일: 09/06/23
99 평판
안내서 1개 작성함
Austin Community College, Team 8-1, Watkins Fall 2023 Austin Community College, Team 8-1, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S8G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 104
