소개
After troubleshooting your device if you determine that you need to replace your battery this guide is for you. This guide will teach the user to remove and replace the battery on the HP Chromebook 11 G8 EE.
Before following this guide, be sure to power off the device and remove any external power sources.
The user should be wary of a hot, swollen looking, or off smelling battery which may result in a fire if handled incorrectly. Always properly recycle spent batteries.
필요한 것
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
