주요 콘텐츠로 건너뛰기
HP Chromebook 11A G6 EE Display Panel Hinges Replacement
필요한 것
  1. HP Chromebook 11A G6 EE Display Panel Hinges Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Display Panel Hinges Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Display Panel Hinges Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 2 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
  4. HP Chromebook 11A G6 EE Display Panel Hinges Replacement, Display Panel Hinges: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the 2.5 mm screw connected to the wireless module.
    • Gently peel back the tape and lift the wireless module out.
    • Take careful note of the routing of the wires from the display panel to the wireless module.
  5. HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 5 단계, 이미지 2개 중 1개 HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 5 단계, 이미지 2개 중 2개
    • Using your iFixit opening tool, ease it in between the frame of the top case, and lift it up.
    • Slide your opening tool clockwise around the edge of the laptop, separating the front panel from the top case.
    • Lay the laptop flat if possible.
    • Carefully lift the frame and bring the top of the top cover towards you.
    • There will be adhesive connecting the frame to the LCD display.
    • Once the frame is about 90 degrees from the base, pull the bottom of the frame towards you, separating the frame from the top case.
  6. HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the five 2mm screws from the display panel bezel.
  7. HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the three 2.5 mm screws that secure each display panel hinge to the display enclosure.
    • Lift the tops of the left and right hinges towards you, separating them from the top case.
    • Use a Phillips #1 screwdriver to remove the two 2.5 mm screws that secure the hinge to the bottom case.
  8. HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 8 단계, 이미지 1개 중 1개
    • Peel back the tape that secures the webcam to the left display panel hinge.
    • Gently slide out the webcam connector.
    • Separate the cable before removing the hinge to prevent pinching.
    • Take careful note of the routing of the cables.
  9. HP Chromebook 11A G6 EE Display Panel Hinges Replacement: 9 단계, 이미지 1개 중 1개
    • Rotate the hinge away from you while applying slight pressure toward the middle of the device to slide it out of the encasement.
    • Repeat this step for the right hinge.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jeff Johnson
회원 가입일: 09/06/23
303 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 37
전체 시간: 354
