주요 콘텐츠로 건너뛰기
HP Chromebook 11A G6 EE Keyboard Replacement
필요한 것
  1. HP Chromebook 11A G6 EE Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Keyboard Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11A G6 EE Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
결론
작성자
5다른 기여자 명과 함께
William S
회원 가입일: 09/25/22
575 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 502
