주요 콘텐츠로 건너뛰기
HP Chromebook 11A G6 EE Motherboard Replacement
필요한 것
  1. HP Chromebook 11A G6 EE Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Motherboard Replacement: 2 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Motherboard Replacement: 2 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Motherboard Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 11A G6 EE Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the cables out.
    • Lift the keyboard off the to remove.
  4. HP Chromebook 11A G6 EE Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the 2.5 mm screw connected to the wireless module.
    • Gently peel back the tape and slide the wireless module out.
    • Take careful note of the routing of the wires from the display panel to the wireless module.
  5. HP Chromebook 11A G6 EE Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Peel back the tape that secures the webcam to the left display panel hinge.
    • Gently slide out the webcam connector.
    • Take note of the routing of the webcam connector cable.
  6. HP Chromebook 11A G6 EE Motherboard Replacement: 6 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Motherboard Replacement: 6 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Release the tape that secures the battery cable connector to the system board.
    • Disconnect the battery cable from the system board. Pull the cable straight out of the connector by the white plastic portion near the connection point.
    • Don't pull the cable out by the wire or it may become damaged.
  7. HP Chromebook 11A G6 EE Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook 11A G6 EE Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Peel the tape off of the speaker cable connector.
    • Disconnect the speaker cable from the system board. Pull the cable straight out of the connector by the black plastic portion near the connection point. Disconnect the speaker cable from the system board.
    • To avoid damage, don't pull on the wires.
  8. HP Chromebook 11A G6 EE Motherboard Replacement: 8 단계, 이미지 3개 중 1개 HP Chromebook 11A G6 EE Motherboard Replacement: 8 단계, 이미지 3개 중 2개 HP Chromebook 11A G6 EE Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Peel back retention tape.
    • Use pry tool carefully to disconnect LCD cable from motherboard. Lift up on the back arm of the connection cable.
    • Be careful when removing connection, mishandling can cause serious damage to your notebook.
  9. HP Chromebook 11A G6 EE Motherboard Replacement: 9 단계, 이미지 2개 중 1개 HP Chromebook 11A G6 EE Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the 5 M2x3.5 PH1 screws from motherboard.
    • Peel back protective tape, lift up on the back arm of the ZIF connector cable. Use prytool very carefully if needed to remove connectors.
    • Very little to no force should be required to remove connectors if done correctly.
    • Once screws are out, peel back the protective tape at the Wifi card socket. Carefully place finger on/under socket card connection area for leverage.
    • Make sure no cables are under motherboard when replacing and putting back together.
    • Be careful when removing connections as mishandling can cause serious damage to your notebook.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Scott
회원 가입일: 09/06/23
365 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 387
