주요 콘텐츠로 건너뛰기
HP Chromebook CB2L Motherboard Replacement
필요한 것
  1. HP Chromebook CB2L Motherboard Replacement, Battery: 1 단계, 이미지 1/2 HP Chromebook CB2L Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Motherboard Replacement: 2 단계, 이미지 1/3 HP Chromebook CB2L Motherboard Replacement: 2 단계, 이미지 2/3 HP Chromebook CB2L Motherboard Replacement: 2 단계, 이미지 3/3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Motherboard Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Motherboard Replacement: 4 단계, 이미지 1/1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Motherboard Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Motherboard Replacement, Speaker: 6 단계, 이미지 1/1
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Motherboard Replacement: 8 단계, 이미지 1/3 HP Chromebook CB2L Motherboard Replacement: 8 단계, 이미지 2/3 HP Chromebook CB2L Motherboard Replacement: 8 단계, 이미지 3/3
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Motherboard Replacement: 9 단계, 이미지 1/1
    • Use the plastic opening tool to remove the speaker from back panel.
  10. HP Chromebook CB2L Motherboard Replacement, Motherboard: 10 단계, 이미지 1/3 HP Chromebook CB2L Motherboard Replacement, Motherboard: 10 단계, 이미지 2/3 HP Chromebook CB2L Motherboard Replacement, Motherboard: 10 단계, 이미지 3/3
    • Disconnect the black wire which connects the audio port to the motherboard.
    • Use the plastic opening tool to lift the white tab.
    • Use the plastic opening tool to disconnect the gold strip which connects the audio port to the motherboard.
  11. HP Chromebook CB2L Motherboard Replacement: 11 단계, 이미지 1/2 HP Chromebook CB2L Motherboard Replacement: 11 단계, 이미지 2/2
    • Lift the black tab using the plastic opening tool.
    • Remove the two white strips from the motherboard.
  12. HP Chromebook CB2L Motherboard Replacement: 12 단계, 이미지 1/2 HP Chromebook CB2L Motherboard Replacement: 12 단계, 이미지 2/2
    • Lift the black and silver connector using plastic opening tool as shown.
    • Remove the white and black wires by rotating them counterclockwise and gently lifting them.
  13. HP Chromebook CB2L Motherboard Replacement: 13 단계, 이미지 1/3 HP Chromebook CB2L Motherboard Replacement: 13 단계, 이미지 2/3 HP Chromebook CB2L Motherboard Replacement: 13 단계, 이미지 3/3
    • Remove the three 1.2mm screws using the Phillips #1 screwdriver.
  14. HP Chromebook CB2L Motherboard Replacement: 14 단계, 이미지 1/1
    • Using the plastic opening tool lift the motherboard out of the back panel.
결론
Gregory Hinkson
회원 가입일: 02/13/17
352 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G6, Lacy Spring 2017 USF Tampa, Team S2-G6, Lacy Spring 2017 회원
USFT-LACY-S17S2G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 629
