주요 콘텐츠로 건너뛰기
HP Compaq Presario CQ56-110US Keyboard Replacement
필요한 것
동영상 개요
  1. HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
    • Push the latch to the unlocked position.
  2. HP Compaq Presario CQ56-110US Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Gently take out the battery.
  3. HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • On the back panel of the laptop are two screws which have a keyboard symbol next to them.
    • Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
  4. HP Compaq Presario CQ56-110US Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Compaq Presario CQ56-110US Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • From left to right, unscrew the 5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
  5. HP Compaq Presario CQ56-110US Keyboard Replacement: 5 단계, 이미지 2개 중 1개 HP Compaq Presario CQ56-110US Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel using a plastic opening tool.
  6. HP Compaq Presario CQ56-110US Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
  7. HP Compaq Presario CQ56-110US Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Flip the laptop back over and lift the lid to expose the keyboard.
  8. HP Compaq Presario CQ56-110US Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq Presario CQ56-110US Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry up the keyboard.
  9. HP Compaq Presario CQ56-110US Keyboard Replacement: 9 단계, 이미지 2개 중 1개 HP Compaq Presario CQ56-110US Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Once the keyboard is lifted, disconnect the band.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Iyonna L. Tynes
회원 가입일: 02/15/17
446 평판
안내서 3개를 작성함
USF Tampa, Team 8-4, Eyestone Spring 2017 USF Tampa, Team 8-4, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G4
4 회원들
안내서 5개를 작성함
댓글 한 개
Difficulty HARD ? oh please… please change to EASY… just some screws?
Assembler Computer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 39
전체 시간: 3,624
