주요 콘텐츠로 건너뛰기
HP Compaq nc6400 Bluetooth Module Replacement
필요한 것
  1. HP Compaq nc6400 Bluetooth Module Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Bluetooth Module Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Bluetooth Module Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    10.8 volt ????
    OK ?
    Gilbert Baum - 답글
    the volt is 10.8,,?
    Gilbert Baum - 답글
  4. HP Compaq nc6400 Bluetooth Module Replacement: 4 단계, 이미지 1개 중 1개
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Bluetooth Module Replacement, Bluetooth Module: 5 단계, 이미지 1개 중 1개
    • Flip the computer top down and locate the second to-the-right 1.2 Philips #1 screw in the bottom-left corner.
    • Remove the screw.
  6. HP Compaq nc6400 Bluetooth Module Replacement: 6 단계, 이미지 3개 중 1개 HP Compaq nc6400 Bluetooth Module Replacement: 6 단계, 이미지 3개 중 2개 HP Compaq nc6400 Bluetooth Module Replacement: 6 단계, 이미지 3개 중 3개
    • Lift the right side of the Bluetooth Module cover upwards.
    • Slide the spudger under the lifted case, and slide it left towards the closed end. The case will pop open and be removed from the compartment.
  7. HP Compaq nc6400 Bluetooth Module Replacement: 7 단계, 이미지 1개 중 1개
    • Locate the Bluetooth Module after removing the cover.
    • Using the spudger, push the module to the right (i.e. towards the screw hole).
    • Pull outwards and remove bluetooth module and wire from casing.
  8. HP Compaq nc6400 Bluetooth Module Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq nc6400 Bluetooth Module Replacement: 8 단계, 이미지 2개 중 2개
    • Once the module and wire are completely outside of the casing, gently pull apart the wire from the module clip.
    Bluetooth cover price
    Anil das - 답글
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Yoshitake Yamada
회원 가입일: 09/30/13
266 평판
안내서 2개를 작성함
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 회원
CPSU-FORTE-F13S14G6
5 회원들
안내서 5개를 작성함
1가이드 댓글
Hi,
My HP nx9420 did not have the Bluetooth. I wish to install one. I got one from my old HP nx9420. it Part Number is 397922-001 but the actual laptop says it requires the 409993-001 are these module the same ?
thanks
Alain
Alain Bastien - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 2,228
