주요 콘텐츠로 건너뛰기
HP EliteBook 840 G5 Keyboard Replacement
필요한 것
  1. HP EliteBook 840 G5 Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 Keyboard Replacement: 2 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement: 2 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
  4. HP EliteBook 840 G5 Keyboard Replacement, Remove the two screws: 4 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Remove the two screws: 4 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Remove the two screws: 4 단계, 이미지 3개 중 3개
    • When you removed the back cover successfully, remove the 2 PH1 screws which are holding the keyboard.
    • The screws with the text "KB" are the correct screws to remove.
  5. HP EliteBook 840 G5 Keyboard Replacement, Free the keyboard: 5 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Free the keyboard: 5 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Free the keyboard: 5 단계, 이미지 3개 중 3개
    • I recommend to use the iFixit Opening Picks for this step! Otherwise you could scratch/damage the keyboard or frame by metal on metal!
    • Place it between the keyboard and the frame. I started near the on/off button to make a opening.
    • Just go around the whole keyboard with the opening picks, slide it through every side of the keyboard, except for the under side (there are no clips there).
    • Just free all the clips, you should hear some pops. Do not pull the keyboard out, just free it from the clips which are holding the keyboard. The clips that are holding the keyboard are pretty strong, so you need a little force to free it.
  6. HP EliteBook 840 G5 Keyboard Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Remove the keyboard: 6 단계, 이미지 3개 중 3개
    • After it's freed from all the clips, you can turn the keyboard towards your self, but hold the keyboard with one hand!
    • Do not remove the keyboard as it's still connected with some ribbon cables! The ribbon cables can rip easily!
    • Do not pull the cables yet. The ribbon cables are still connected to the ZIF connectors, pulling the cables without opening the ZIF connectors could break them!
    • Now open up the ZIF connector and pull on the blue tab to remove the cable.
  7. HP EliteBook 840 G5 Keyboard Replacement, Disconnect the keyboard ribbon cable: 7 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Disconnect the keyboard ribbon cable: 7 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Disconnect the keyboard ribbon cable: 7 단계, 이미지 3개 중 3개
    • Open up the ZIF connector with your nail or plastic opening tool, but be careful as they can break easily!
    • Hold the blue tab on the keyboard cable.
    • And pull on the blue tab to remove the cable from the ZIF connector straight out the socket.
  8. HP EliteBook 840 G5 Keyboard Replacement, Remove the pointer ribbon cable: 8 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Remove the pointer ribbon cable: 8 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Remove the pointer ribbon cable: 8 단계, 이미지 3개 중 3개
    • Open up the ZIF connector carefully.
    • Hold on the blue tab.
    • Remove the cable straight out the socket.
  9. HP EliteBook 840 G5 Keyboard Replacement, Remove backlight ribbon cable: 9 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Remove backlight ribbon cable: 9 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Remove backlight ribbon cable: 9 단계, 이미지 3개 중 3개
    • Repeat the process for this ribbon cable as well.
    • This cable is still holding to the frame with lightly adhesive on two places, just pull on it Carefully to remove it from the frame.
  10. HP EliteBook 840 G5 Keyboard Replacement, Remove the keyboard: 10 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Remove the keyboard: 10 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Remove the keyboard: 10 단계, 이미지 3개 중 3개
    • 2nd place which has lightly adhesive on it.
    • After it's freed now, you can successfully remove the keyboard!
  11. HP EliteBook 840 G5 Keyboard Replacement, Set-up new keyboard: 11 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Set-up new keyboard: 11 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Set-up new keyboard: 11 단계, 이미지 3개 중 3개
    • If you going to replace it for a new keyboard, it's possible that you need to transfer one cable from the old keyboard to the new one. Do the same process as earlier to transfer it.
    • Some models only have 2 connectors on the keyboards and/or motherboards, this is because it's simply missing the black light feature.
  12. HP EliteBook 840 G5 Keyboard Replacement, Connect the keyboard again: 12 단계, 이미지 3개 중 1개 HP EliteBook 840 G5 Keyboard Replacement, Connect the keyboard again: 12 단계, 이미지 3개 중 2개 HP EliteBook 840 G5 Keyboard Replacement, Connect the keyboard again: 12 단계, 이미지 3개 중 3개
    • Be hold that you need to pull of the plastics from the new tape to attach it again on the frame.
    • Follow the guide in reverse to connect the new keyboard again.
    • This should be it! Please test everything to check if it works.
결론
Please be sure that you transferred the cable from the old keyboard to the new one.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
koppie007
회원 가입일: 08/22/13
37,957 평판
안내서 9개를 작성함
1가이드 댓글
okay so i droped my laptop and the mouse was fine before I dropped it and know the touchpad is not clicking all the way down and its stiff and its bending down in the slot
fklnhr 45io649 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 76
지난 30일: 386
전체 시간: 37,999
