주요 콘텐츠로 건너뛰기
HP EliteBook 8470p Case/Service Cover Replacement
  1. HP EliteBook 8470p Case/Service Cover Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Case/Service Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Case/Service Cover Replacement: 3 단계, 이미지 1개 중 1개
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Case/Service Cover Replacement, Case/Service Cover: 4 단계, 이미지 1개 중 1개
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Case/Service Cover Replacement: 5 단계, 이미지 2개 중 1개 HP EliteBook 8470p Case/Service Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Owen Bangs
회원 가입일: 10/25/22
696 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S5G3
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 29
전체 시간: 853
