소개
If your HP EliteBook 850 G3 is not holding a charge use this guide to replace the battery. The battery powers the laptop if it is faulty the computer will not keep a charge. If your battery is swollen this is urgent and dangerous. Be sure to rule out a faulty cord and other common issues that could be preventing your battery from charging properly. Before using this guide, feel free to check out the troubleshooting page to see if any issues can be resolved without a replacement.
필요한 것
Use the Phillips #0 screwdriver to remove the two battery screws.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Thank you very much for this guide.
When charging the charging indicator remain orange for hours and does not change.
