주요 콘텐츠로 건너뛰기
HP EliteBook 850 G3 Motherboard Replacement
필요한 것
  1. HP EliteBook 850 G3 Motherboard Replacement, WiFi Card: 1 단계, 이미지 1/1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 Motherboard Replacement: 2 단계, 이미지 1/2 HP EliteBook 850 G3 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Motherboard Replacement: 3 단계, 이미지 1/2 HP EliteBook 850 G3 Motherboard Replacement: 3 단계, 이미지 2/2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 Motherboard Replacement: 5 단계, 이미지 1/2 HP EliteBook 850 G3 Motherboard Replacement: 5 단계, 이미지 2/2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 Motherboard Replacement: 6 단계, 이미지 1/3 HP EliteBook 850 G3 Motherboard Replacement: 6 단계, 이미지 2/3 HP EliteBook 850 G3 Motherboard Replacement: 6 단계, 이미지 3/3
    • Disconnect the coaxial cables wires from the WiFi card.
  7. HP EliteBook 850 G3 Motherboard Replacement, Fan: 7 단계, 이미지 1/1
    • Gently unclip the plastic frame.
  8. HP EliteBook 850 G3 Motherboard Replacement: 8 단계, 이미지 1/3 HP EliteBook 850 G3 Motherboard Replacement: 8 단계, 이미지 2/3 HP EliteBook 850 G3 Motherboard Replacement: 8 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  9. HP EliteBook 850 G3 Motherboard Replacement: 9 단계, 이미지 1/2 HP EliteBook 850 G3 Motherboard Replacement: 9 단계, 이미지 2/2
    • Carefully remove the connector for the fan.
  10. HP EliteBook 850 G3 Motherboard Replacement: 10 단계, 이미지 1/3 HP EliteBook 850 G3 Motherboard Replacement: 10 단계, 이미지 2/3 HP EliteBook 850 G3 Motherboard Replacement: 10 단계, 이미지 3/3
    • Carefully remove the fan and heatsink assembly from the laptop.
    • Slide out RAM (not pictured).
  11. HP EliteBook 850 G3 Motherboard Replacement: 12 단계, 이미지 1/1
    • Use a #00 Phillips screwdriver to remove twelve 5.7 mm screws from the motherboard.
  12. HP EliteBook 850 G3 Motherboard Replacement: 13 단계, 이미지 1/3 HP EliteBook 850 G3 Motherboard Replacement: 13 단계, 이미지 2/3 HP EliteBook 850 G3 Motherboard Replacement: 13 단계, 이미지 3/3
    • Remove the wire connectors.
  13. HP EliteBook 850 G3 Motherboard Replacement: 14 단계, 이미지 1/2 HP EliteBook 850 G3 Motherboard Replacement: 14 단계, 이미지 2/2
    • Jiggle the motherboard until the ports (ie. headphone jack) come out from the sides and you can lift it up.
  14. HP EliteBook 850 G3 Motherboard Replacement: 15 단계, 이미지 1/3 HP EliteBook 850 G3 Motherboard Replacement: 15 단계, 이미지 2/3 HP EliteBook 850 G3 Motherboard Replacement: 15 단계, 이미지 3/3
    • Disconnect the wires underneath.
  15. HP EliteBook 850 G3 Motherboard Replacement: 16 단계, 이미지 1/3 HP EliteBook 850 G3 Motherboard Replacement: 16 단계, 이미지 2/3 HP EliteBook 850 G3 Motherboard Replacement: 16 단계, 이미지 3/3
    • Take out the motherboard.
결론
Annabeth Grover
회원 가입일: 10/10/19
922 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G1, Leahy Fall 2019 USF Tampa, Team S1-G1, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 54
전체 시간: 3,325
