주요 콘텐츠로 건너뛰기
HP EliteBook 850 G3 WiFi Card Replacement
필요한 것
  1. HP EliteBook 850 G3 WiFi Card Replacement, WiFi Card: 1 단계, 이미지 1/1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 WiFi Card Replacement: 2 단계, 이미지 1/2 HP EliteBook 850 G3 WiFi Card Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 WiFi Card Replacement: 3 단계, 이미지 1/2 HP EliteBook 850 G3 WiFi Card Replacement: 3 단계, 이미지 2/2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 WiFi Card Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 WiFi Card Replacement: 5 단계, 이미지 1/2 HP EliteBook 850 G3 WiFi Card Replacement: 5 단계, 이미지 2/2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 WiFi Card Replacement: 6 단계, 이미지 1/3 HP EliteBook 850 G3 WiFi Card Replacement: 6 단계, 이미지 2/3 HP EliteBook 850 G3 WiFi Card Replacement: 6 단계, 이미지 3/3
    • Disconnect the coaxial cables wires from the WiFi card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Annabeth Grover
회원 가입일: 10/10/19
922 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G1, Leahy Fall 2019 USF Tampa, Team S1-G1, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
MV9000 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 30
전체 시간: 1,536
