주요 콘텐츠로 건너뛰기
HP EliteBook 8560w CD/DVD ROM Replacement
필요한 것
  1. HP EliteBook 8560w CD/DVD ROM Replacement, Battery: 1 단계, 이미지 1/2 HP EliteBook 8560w CD/DVD ROM Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w CD/DVD ROM Replacement: 2 단계, 이미지 1/1
    • Pull the battery out.
  3. HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: 3 단계, 이미지 1/2 HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: 3 단계, 이미지 2/2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w CD/DVD ROM Replacement: 4 단계, 이미지 1/1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: 5 단계, 이미지 1/2 HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: 5 단계, 이미지 2/2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w CD/DVD ROM Replacement: 6 단계, 이미지 1/3 HP EliteBook 8560w CD/DVD ROM Replacement: 6 단계, 이미지 2/3 HP EliteBook 8560w CD/DVD ROM Replacement: 6 단계, 이미지 3/3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w CD/DVD ROM Replacement: 7 단계, 이미지 1/2 HP EliteBook 8560w CD/DVD ROM Replacement: 7 단계, 이미지 2/2
    • Pull out the CD/DVD ROM with your hand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Kim
회원 가입일: 01/14/20
188 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 571
