주요 콘텐츠로 건너뛰기
HP EliteBook 8560w Keyboard Replacement
필요한 것
  1. HP EliteBook 8560w Keyboard Replacement, Battery: 1 단계, 이미지 1/2 HP EliteBook 8560w Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Keyboard Replacement: 2 단계, 이미지 1/1
    • Pull the battery out.
  3. HP EliteBook 8560w Keyboard Replacement, Back Panel: 3 단계, 이미지 1/2 HP EliteBook 8560w Keyboard Replacement, Back Panel: 3 단계, 이미지 2/2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Keyboard Replacement: 4 단계, 이미지 1/1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: 5 단계, 이미지 1/2 HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: 5 단계, 이미지 2/2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w Keyboard Replacement: 6 단계, 이미지 1/3 HP EliteBook 8560w Keyboard Replacement: 6 단계, 이미지 2/3 HP EliteBook 8560w Keyboard Replacement: 6 단계, 이미지 3/3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w Keyboard Replacement: 7 단계, 이미지 1/2 HP EliteBook 8560w Keyboard Replacement: 7 단계, 이미지 2/2
    • Pull out the CD/DVD ROM with your hand.
  8. HP EliteBook 8560w Keyboard Replacement, Keyboard: 8 단계, 이미지 1/1
    • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
  9. HP EliteBook 8560w Keyboard Replacement: 9 단계, 이미지 1/3 HP EliteBook 8560w Keyboard Replacement: 9 단계, 이미지 2/3 HP EliteBook 8560w Keyboard Replacement: 9 단계, 이미지 3/3
    • Put your finger through the hole to push out the keyboard from its place.
    • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
  10. HP EliteBook 8560w Keyboard Replacement: 10 단계, 이미지 1/3 HP EliteBook 8560w Keyboard Replacement: 10 단계, 이미지 2/3 HP EliteBook 8560w Keyboard Replacement: 10 단계, 이미지 3/3
    • Carefully lift keyboard to reveal connection strips.
    • Unlock the latch holding the connection strips.
    • Pull out the connection strips from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jarret Williams
회원 가입일: 01/14/20
148 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 15
30일 전: 20
전체 시간: 1,395
