주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Screen Replacement
필요한 것
  1. HP EliteBook x360 1030 G3 Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Before starting, make sure your laptop is completely powered off.
    • Open the laptop and position the screen to face you.
    • Carefully wedge a Jimmy between the black screen border and the silver monitor backing, and then rotate the Jimmy upwards and away from you until they separate.
    • If your screen is not cracked, there is a chance of doing so here. Perform this step with caution, control, and focus.
  2. HP EliteBook x360 1030 G3 Screen Replacement: 2 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Screen Replacement: 2 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Reinsert the Jimmy and slowly twist it to begin separating the remainder of the screen.
    • Continue this along the edge until the top and two sides are fully separated.
    • Allow the top edge of the screen to rest against the keyboard.
  3. HP EliteBook x360 1030 G3 Screen Replacement: 3 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the tape off the gold wire port on the left.
  4. HP EliteBook x360 1030 G3 Screen Replacement: 4 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • There is a thin hinged bar hugging the front of the port to keep the wire housing in place. Use your nail or a thin object to lift it up and out of the way.
    • Use the hinged bar to slide the wire housing away from you and out of the port.
  5. HP EliteBook x360 1030 G3 Screen Replacement: 5 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the collection of ports on the right.
    • Pull the tape from the port with the thicker orange sheet of wires and from the port on the small green circuit board.
  6. HP EliteBook x360 1030 G3 Screen Replacement: 6 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use your nail or a thin object to lift the small white fastener at the front of the port.
    • Slide the orange sheet away from you out of the port.
  7. HP EliteBook x360 1030 G3 Screen Replacement: 7 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Screen Replacement: 7 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Use your nail or a thin object to lift the small white fastener at end of the port on the green circuit board.
    • Slide the sheet of wires to the right and out of the port.
    • Carefully lift, and remove the screen.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Shea Charkowsky
회원 가입일: 04/15/19
816 평판
안내서 3개를 작성함
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 회원
CPSU-MANESS-S19S2G9
4 회원들
안내서 16개를 작성함
댓글 한 개
I tried to perform this operation, since the top cover got a scratch and a ding. I bought a replacement top cover and tried to reinstall a perfectly working screen from one cover to another. I followed this manual to step 2 and realized that top is easy, sides are much harder. On the sides with the opener tool you start to touch directly the screen glass so the “slowly twist“ move suggested in this manual would likely create cracks in it. Finally I decided not to execute this procedure since the risk of losing the screen is too high. In case you replace a broken screen - then it is ok.
Nuc - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 54
지난 30일: 146
전체 시간: 10,778
