주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G7 Motherboard Replacement
필요한 것
  1. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the backplate: 1 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the backplate: 1 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the backplate: 1 단계, 이미지 3개 중 3개
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Motherboard Replacement, Disconnect the bundled cable connector: 2 단계, 이미지 1개 중 1개
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Motherboard Replacement, Peel the copper foil tape: 3 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Peel the copper foil tape: 3 단계, 이미지 2개 중 2개
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the screws: 4 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the screws: 4 단계, 이미지 2개 중 2개
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the backplate: 6 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the backplate: 6 단계, 이미지 2개 중 2개
    • Turn the computer over so the back is facing up.
  7. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the shield: 7 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the shield: 7 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the shield: 7 단계, 이미지 3개 중 3개
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  8. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the RAM: 8 단계, 이미지 1개 중 1개
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
  9. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the backplate: 9 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the backplate: 9 단계, 이미지 2개 중 2개
  10. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the metal shield covering the SSD: 10 단계, 이미지 1개 중 1개
    • Lift the metal shielding off of the solid state drive.
  11. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the screw: 11 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the screw: 11 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the screw: 11 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  12. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the SSD: 12 단계, 이미지 1개 중 1개
    • Gently pull the SSD free from the M.2 socket.
  13. HP EliteBook x360 830 G7 Motherboard Replacement, Display panel cable: 13 단계, 이미지 1개 중 1개
    • Disconnect the display panel cable from it's connector on the motherboard.
  14. HP EliteBook x360 830 G7 Motherboard Replacement, Necessities that help keep the fan in place: 14 단계, 이미지 1개 중 1개
    • Remove the display panel and the wireless antenna cables from the routing channels. Then, remove the retention tape from the system fan.
  15. HP EliteBook x360 830 G7 Motherboard Replacement, Loosen the screws: 15 단계, 이미지 1개 중 1개
    • Loosen the JIS #1 screws that secure the system fan to the motherboard.
    • These screws are captive.
  16. HP EliteBook x360 830 G7 Motherboard Replacement, Remove the fan: 16 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Remove the fan: 16 단계, 이미지 2개 중 2개
    • Once all of the connectors and screws that secure the fan in place have been removed sucessfully, you can safely remove the system fan from the motherboard.
  17. HP EliteBook x360 830 G7 Motherboard Replacement, Motherboard: 17 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement, Motherboard: 17 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Motherboard Replacement, Motherboard: 17 단계, 이미지 3개 중 3개
    • Use a JIS #1 screwdriver to remove the single screw securing the Wi-Fi card.
    • Use a spudger or or angled tweezers under the metal neck of the connector two connectors (as close to the head as possible) and lift straight up from the board to disconnect the coaxial cables.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
    • Slide the Wi-Fi card out of the socket.
  18. HP EliteBook x360 830 G7 Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • A WWAN module is optional in this device. The laptop used in this guide did not contain a WWAN module. Proper photos cannot be provided for this step; the steps will be near identical to the removal of the Wi-Fi card, please refer to the previous step for visuals.
    • If your device contains a WWAN module it will be placed on the far left side of the motherboard. The location of the WWAN module is pictured to the left.
    • Disconnect four cables.
    • Use a JIS #1 screwdriver to remove the single screw.
    • Remove the WWAN module.
  19. HP EliteBook x360 830 G7 Motherboard Replacement: 19 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement: 19 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Motherboard Replacement: 19 단계, 이미지 3개 중 3개
    • Use a JIS #1 screwdrivers to remove five screws securing the plastic bracket.
    • Remove plastic bracket.
  20. HP EliteBook x360 830 G7 Motherboard Replacement: 20 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    • Use the JIS #1 screwdriver to remove four screws securing the metal bracket.
    • Remove metal bracket.
  21. HP EliteBook x360 830 G7 Motherboard Replacement: 21 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement: 21 단계, 이미지 2개 중 2개
    • Use a prying tool to push on alternating sides of the power connector to "walk" it out of its socket and disconnect.
    • Pull straight up on the connector to disconnect camera cable.
  22. HP EliteBook x360 830 G7 Motherboard Replacement: 22 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement: 22 단계, 이미지 2개 중 2개
    • Use the point of a spudger to push on alternating sides of the speaker connector to "walk" it out of its socket.
    • Don't pull on the cables.
    • Disconnecting these cables is a two-step process.
    • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Hold the buckle and cable together and gently pull the connector straight out of its socket.
    • To reconnect, grip the cable and buckle together and insert the connector fully into its socket.
    • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
    • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
  23. HP EliteBook x360 830 G7 Motherboard Replacement: 23 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement: 23 단계, 이미지 2개 중 2개
    • Disconnect touchpad cable. Lift up the small black lock and pull out the ribbon cable.
    • Lift up the small black lock and and pull out the ribbon cable to disconnect keyboard cable.
    • Disconnect keyboard ZIF connector backlight cable (if applicable).
    • Disconnect the ZIF card reader cable (if applicable).
  24. HP EliteBook x360 830 G7 Motherboard Replacement: 24 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement: 24 단계, 이미지 2개 중 2개
    • Use the point of a spudger to push on alternating sides of the RTC battery connector to "walk" it out of its socket and disconnect the RTC battery cable.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • Disconnect NFC module ZIF connector to remove the cable (if applicable).
    • Disconnect Fingerprint reader ZIF connector to remove cable (if applicable).
  25. HP EliteBook x360 830 G7 Motherboard Replacement: 25 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Motherboard Replacement: 25 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to loosen the screws securing the heat sink.
    • These screws are captive and don't need to be removed from the heat sink.
    • Use a JIS #1 screwdriver to remove the remaining screws holding motherboard in place.
    • Lift the left side of the motherboard upwards and pull it out of the laptop.
  26. HP EliteBook x360 830 G7 Motherboard Replacement: 26 단계, 이미지 1개 중 1개
    • Before placing the heatsink, it is extremely important that you place thermal paste on the new cpu. Thermal paste allows for heat to be conducted from your cpu to the heatsink and out of the computer, without this your cpu may become damaged or broken.
    • Follow this guide to replace your thermal paste, the heatsink is pictured to the left. You will need to remove the grey paste from the right end of the heatsink.
    • How to Apply Thermal Paste
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
2다른 기여자 명과 함께
Erikc24
회원 가입일: 02/08/24
181 평판
안내서 1개를 작성함
1가이드 댓글
I think there should be a step to remove the heat sink between the 'remove the fan' step and the 'motherboard' step.
philipahbrooker - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 50
전체 시간: 813
