주요 콘텐츠로 건너뛰기
HP Envy x360 15-bp143cl Battery Replacement
필요한 것
  1. HP Envy x360 15-bp143cl Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Battery Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Battery Replacement: 3 단계, 이미지 1/1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Battery Replacement: 4 단계, 이미지 1/1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Battery Replacement: 5 단계, 이미지 1/2 HP Envy x360 15-bp143cl Battery Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Battery Replacement: 6 단계, 이미지 1/1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Riley Muehler
회원 가입일: 10/10/19
305 평판
안내서 1개 작성함
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 회원
CPSU-REGAN-F19S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you for the pictures and advice!
I did not see any memory. Can you tell me if there are two slots for upgrading? I read that one stick of memory is soldered and the other is socketed.
Regards!
Joseph Stateson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 77
전체 시간: 3,094
