주요 콘텐츠로 건너뛰기
HP Envy x360 15-bp143cl Screen Replacement
필요한 것
  1. HP Envy x360 15-bp143cl Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Use a suction handle to pull the screen display out of the screen casing.
    • If the screen is difficult to remove, use an opening tool to pry the sides of screen from the screen casing.
  2. HP Envy x360 15-bp143cl Screen Replacement: 2 단계, 이미지 1/2 HP Envy x360 15-bp143cl Screen Replacement: 2 단계, 이미지 2/2
    • Lift the screen display from the screen casing, hinging it from the top edge to expose the back of the panel.
    • Do not separate the display from the casing completely, as there are still cable connections holding it in place.
  3. HP Envy x360 15-bp143cl Screen Replacement: 3 단계, 이미지 1/2 HP Envy x360 15-bp143cl Screen Replacement: 3 단계, 이미지 2/2
    • Detach the connecting cable between the laptop and the display screen.
    • Remove the display screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Spencer Berkins
회원 가입일: 10/10/19
574 평판
안내서 4개 작성하였습니다
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 회원
CPSU-REGAN-F19S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you for this great guide, been very useful knowing how to remove the screen from th housing! However; I'm looking to replace not the screen but the 'screen housing' as the plastic bracket that the hinges screw into (three round flat screws you can see for each hinge) has torn. Very bad design IMHO. The entire screw/bolt has just torn free (all three) on the right hinge. Seeing as the plastic bracket is glued to the metal casing it is irreparable…
Anybody know where I can get the replacement (my HP Envy has a metal/aluminium housing in silver colour).
Kind regards,
Adrian
Adrian Munro - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 19
30일 전: 104
전체 시간: 4,104
