주요 콘텐츠로 건너뛰기
HP Envy x360 15-bp143cl Touchpad Replacement
필요한 것
  1. HP Envy x360 15-bp143cl Touchpad Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Touchpad Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Touchpad Replacement: 3 단계, 이미지 1/1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Touchpad Replacement: 4 단계, 이미지 1/1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Touchpad Replacement: 5 단계, 이미지 1/2 HP Envy x360 15-bp143cl Touchpad Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Touchpad Replacement: 6 단계, 이미지 1/1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: 7 단계, 이미지 1/2 HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: 7 단계, 이미지 2/2
    • Use a spudger to peel the silver tape near the top right side of the touch pad.
  8. HP Envy x360 15-bp143cl Touchpad Replacement: 8 단계, 이미지 1/2 HP Envy x360 15-bp143cl Touchpad Replacement: 8 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 4mm screws securing the bottom metal bar.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 1mm screws securing the top of the touch pad.
  9. HP Envy x360 15-bp143cl Touchpad Replacement: 9 단계, 이미지 1/1
    • Remove the metal cover by lifting it away from the laptop.
  10. HP Envy x360 15-bp143cl Touchpad Replacement: 10 단계, 이미지 1/2 HP Envy x360 15-bp143cl Touchpad Replacement: 10 단계, 이미지 2/2
    • Lift the bottom side of the touch pad.
    • Lift the black tab that secures the touch pad connecting cable to the laptop.
    • Pull the cable from the touch pad connecting port.
  11. HP Envy x360 15-bp143cl Touchpad Replacement: 11 단계, 이미지 1/2 HP Envy x360 15-bp143cl Touchpad Replacement: 11 단계, 이미지 2/2
    • Lift the touch pad to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Spencer Berkins
회원 가입일: 10/10/19
574 평판
안내서 4개 작성하였습니다
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 회원
CPSU-REGAN-F19S12G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thanks now have to find one on E-bay….or?
Michael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 29
전체 시간: 1,465
