주요 콘텐츠로 건너뛰기
HP Envy x360 m6-w105dx Fan Replacement
필요한 것
  1. HP Envy x360 m6-w105dx Fan Replacement, Keyboard: 1 단계, 이미지 1/3 HP Envy x360 m6-w105dx Fan Replacement, Keyboard: 1 단계, 이미지 2/3 HP Envy x360 m6-w105dx Fan Replacement, Keyboard: 1 단계, 이미지 3/3
    • Make sure the laptop is powered off and disconnected from any outlets.
    • Use the opening pick to lift up the eight rubber grips on the underside of the device.
    • With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
  2. HP Envy x360 m6-w105dx Fan Replacement: 2 단계, 이미지 1/2 HP Envy x360 m6-w105dx Fan Replacement: 2 단계, 이미지 2/2
    • Open the laptop and turn to the keyboard.
    • Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
    • Lift the keyboard panel from the bottom and carefully start to lift up.
    • There are ribbon cables still connected on the under side of the the keyboard. Do not pull the keyboard away from the device.
  3. HP Envy x360 m6-w105dx Fan Replacement: 3 단계, 이미지 1/2 HP Envy x360 m6-w105dx Fan Replacement: 3 단계, 이미지 2/2
    • Gently lift the keyboard up from the bottom.
    • Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
    • Do not remove the ZIF connectors by pulling on the wires, instead detach them by gently flipping up the plastic tabs located at the ends of the wiring.
    • Fully remove the keyboard from the laptop and install your new keyboard.
  4. HP Envy x360 m6-w105dx Fan Replacement, Fan: 4 단계, 이미지 1/3 HP Envy x360 m6-w105dx Fan Replacement, Fan: 4 단계, 이미지 2/3 HP Envy x360 m6-w105dx Fan Replacement, Fan: 4 단계, 이미지 3/3
    • Unscrew the five 4mm screws with the #01 phillips head screw driver.
    • Gently flip open the ZIF connectors and remove the ribbon cables.
    • Unscrew the WLAN chip and push the chip up and out of the port.
  5. HP Envy x360 m6-w105dx Fan Replacement: 5 단계, 이미지 1/2 HP Envy x360 m6-w105dx Fan Replacement: 5 단계, 이미지 2/2
    • Disconnect the cable connectors for each of the speakers.
    • Lift the motherboard up and flip towards you to disconnect an additional cable connector on the rear side.
    • Remove motherboard and fan assembly from the laptop.
  6. HP Envy x360 m6-w105dx Fan Replacement: 6 단계, 이미지 1/3 HP Envy x360 m6-w105dx Fan Replacement: 6 단계, 이미지 2/3 HP Envy x360 m6-w105dx Fan Replacement: 6 단계, 이미지 3/3
    • Unscrew the seven spring locked screws with the #1 Phillips screwdriver.
    • Once all screws are out, remove the fan by lifting it up from the motherboard.
  7. HP Envy x360 m6-w105dx Fan Replacement: 7 단계, 이미지 1/1
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dalton Hancock
회원 가입일: 01/24/20
417 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 12
전체 시간: 664
