주요 콘텐츠로 건너뛰기
HP G72 Hard Drive Replacement
필요한 것
  1. HP G72 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 HP G72 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 HP G72 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
  2. HP G72 Hard Drive Replacement: 2 단계, 이미지 1/3 HP G72 Hard Drive Replacement: 2 단계, 이미지 2/3 HP G72 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Loosen the two Phillips 2.5×6.0 captive screws that secure the hard drive cover to the computer.
    • The cover is snapped in by some clips. Use a plastic opening tool on both sides to remove the cover.
  3. HP G72 Hard Drive Replacement: 3 단계, 이미지 1/3 HP G72 Hard Drive Replacement: 3 단계, 이미지 2/3 HP G72 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove the cover
    • Remove the four Phillips M2.5x5.0 screws
    • Disconnect the hard drive cable from the system board.
  4. HP G72 Hard Drive Replacement: 4 단계, 이미지 1/3 HP G72 Hard Drive Replacement: 4 단계, 이미지 2/3 HP G72 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove the hard drive from the hard drive bay
    • Remove the hard drive cable from the drive.
    • Remove the four (two on either side) Phillips M3.0×4.0 screws that secure the hard drive bracket to the hard drive
결론
다른 9명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
785,451 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 578개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 51
전체 시간: 7,266
