주요 콘텐츠로 건너뛰기
HP Omen 15-ax243dx Battery Replacement
필요한 것
  1. HP Omen 15-ax243dx Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Omen 15-ax243dx Battery Replacement, Battery: 1 단계, 이미지 2/2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Battery Replacement: 2 단계, 이미지 1/2 HP Omen 15-ax243dx Battery Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Battery Replacement: 3 단계, 이미지 1/2 HP Omen 15-ax243dx Battery Replacement: 3 단계, 이미지 2/2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Battery Replacement: 4 단계, 이미지 1/2 HP Omen 15-ax243dx Battery Replacement: 4 단계, 이미지 2/2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 5명이 해당 안내서를 완성하였습니다.
vangnam
회원 가입일: 10/19/17
594 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G7
3 회원들
안내서 7개 작성하였습니다
댓글 8개
Hello,
I replaced the battery but it is not charging. I know it’s an easy repair, but I checked the pins but not sure where the problem is.
Any ideas?
Thank you
Kiran M - 답글
Hi Kiran,
Does the laptop show any indication that it detects the battery?
Arthur Shi -
I’ve replaced the battery with one I bought from here, and I believe it may be faulty? My laptop is not detecting a battery, I opened it back up and followed the guide again to make sure I did everything right, and made sure the battery cord was inserting securely, still nothing.
AwSnoopy - 답글
Hello! Please contact our customer support and we will get the issue resolved!
Arthur Shi -
We took the battery out of your laptop then put it back in because it wouldnt turn on, it turns on now but the left usb ports are not getting powered, is there any way to make sure that they are powered when we get our replacement battery in the laptop?
Drake Mitchell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 34
30일 전: 173
전체 시간: 22,627
