주요 콘텐츠로 건너뛰기
HP Pavilion 13-P110NR Keyboard Replacement
필요한 것
  1. HP Pavilion 13-P110NR Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove the two rubber feet closest to the black hinge.
  2. HP Pavilion 13-P110NR Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove two 6.0 mm Philips #00 screws from the back casing.
    • Remove four 5.0 mm Philips #00 screws from the back casing.
  3. HP Pavilion 13-P110NR Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
  4. HP Pavilion 13-P110NR Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the metal brace and remove it from the device.
  5. HP Pavilion 13-P110NR Keyboard Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Unflip the lock on the wire tape and lift that end of the tape away.
    • Do the same for the small white piece of tape on the circuit board.
  6. HP Pavilion 13-P110NR Keyboard Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
  7. HP Pavilion 13-P110NR Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove five 5.0 mm Philips #00 screws from the green circuit boards.
  8. HP Pavilion 13-P110NR Keyboard Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion 13-P110NR Keyboard Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion 13-P110NR Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the white pieces up.
    • Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
  9. HP Pavilion 13-P110NR Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Use caution, the pieces may fly when they are forced out.
  10. HP Pavilion 13-P110NR Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the metal plate to reveal the keyboard.
  11. HP Pavilion 13-P110NR Keyboard Replacement: 11 단계, 이미지 2개 중 1개 HP Pavilion 13-P110NR Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the keyboard from the device.
결론
작성자
3다른 기여자 명과 함께
Matthew "Cole" Corson
회원 가입일: 01/18/18
727 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 368
