주요 콘텐츠로 건너뛰기
HP Pavilion 13-P110NR Screen Replacement
필요한 것
  1. HP Pavilion 13-P110NR Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Remove the back of the laptop screen using a black nylon spudger.
  2. HP Pavilion 13-P110NR Screen Replacement: 2 단계, 이미지 1/1
    • Detach the wires from the green circuit boards located at the bottom.
    • Remove three 3.0 mm #00 Philips screws from the circuit board on the left.
    • Remove two 4.0 mm #00 Philips screws from the small circuit board on the right.
  3. HP Pavilion 13-P110NR Screen Replacement: 3 단계, 이미지 1/1
    • Detach the wires located just above the bigger green circuit board.
  4. HP Pavilion 13-P110NR Screen Replacement: 4 단계, 이미지 1/2 HP Pavilion 13-P110NR Screen Replacement: 4 단계, 이미지 2/2
    • Remove six 4.0 mm Philips #00 screws from the outside of the frame.
    • Remove five 3.0 mm Philips #00 screws from the outside of the frame.
    • Remove the one 3.0 mm Philips #00 screw hidden under the circuit board.
  5. HP Pavilion 13-P110NR Screen Replacement: 5 단계, 이미지 1/1
    • Remove the band that is attached to the circuit board, located on the right side.
  6. HP Pavilion 13-P110NR Screen Replacement: 6 단계, 이미지 1/1
    • Lift the frame and attached hardware from two corners of the frame.
    • Remove the frame from the device.
  7. HP Pavilion 13-P110NR Screen Replacement: 7 단계, 이미지 1/2 HP Pavilion 13-P110NR Screen Replacement: 7 단계, 이미지 2/2
    • Remove the tape located at the top of the frame.
    • Remove the bands from underneath the tape.
  8. HP Pavilion 13-P110NR Screen Replacement: 8 단계, 이미지 1/2 HP Pavilion 13-P110NR Screen Replacement: 8 단계, 이미지 2/2
    • Use the spudger to lift the case, which is attached at four spots by pegs.
    • Remove the metal cover and layers of film.
  9. HP Pavilion 13-P110NR Screen Replacement: 9 단계, 이미지 1/1
    • Use the spudger to gently lift up the screen.
    • There are two layers, go under the bottom layer.
  10. HP Pavilion 13-P110NR Screen Replacement: 10 단계, 이미지 1/1
    • After you get some space at the top of the screen, proceed by using a thin board to gently remove the screen from the frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew "Cole" Corson
회원 가입일: 01/18/18
727 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 425
