주요 콘텐츠로 건너뛰기
HP Pavilion 13-s128nr Battery Replacement
필요한 것
  1. HP Pavilion 13-s128nr Battery Replacement, Back Panel: 1 단계, 이미지 1/2 HP Pavilion 13-s128nr Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Battery Replacement: 2 단계, 이미지 1/1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Battery Replacement: 3 단계, 이미지 1/2 HP Pavilion 13-s128nr Battery Replacement: 3 단계, 이미지 2/2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
  4. HP Pavilion 13-s128nr Battery Replacement, Battery: 4 단계, 이미지 1/2 HP Pavilion 13-s128nr Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Lift upwards on the black tabs the purple strip is connected to.
    • Gently pull the purple strip out of its place.
  5. HP Pavilion 13-s128nr Battery Replacement: 5 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the five screws holding the battery in place.
  6. HP Pavilion 13-s128nr Battery Replacement: 6 단계, 이미지 1/1
    • Pull the white cable connected to the motherboard out using the iFixit opening tool.
  7. HP Pavilion 13-s128nr Battery Replacement: 7 단계, 이미지 1/1
    • Remove the battery.
    • There are little snap tabs on the right side of the battery. Be sure not to break them by pulling the battery out towards the left side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sydney Bell
회원 가입일: 02/13/20
317 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 15
전체 시간: 1,116
