소개
This guide is used for a battery replacement for the HP Pavilion 13-s128nr. The HP Pavilion 13-s128nr is also known as the HP Pavilion x360. A faulty battery will cause the laptop to not work properly. Use this troubleshooting page to know if the battery needs to be replaced. Before beginning this guide, make sure the laptop is powered off.
필요한 것
Use the iFixit opening tool to take off the rubber caps.
Remove the screws using the Phillips #0 screwdriver.
Lift upwards on the black tabs the purple strip is connected to.
Gently pull the purple strip out of its place.
다른 한 분이 해당 안내서를 완성하였습니다.
