주요 콘텐츠로 건너뛰기
HP Pavilion 14 Notebook Battery Replacement
필요한 것
  1. HP Pavilion 14 Notebook Battery Replacement, Remove Enclosure: 1 단계, 이미지 1개 중 1개
    • Unscrew the 5 P1 Philips screws (2 under the rubbers). You can esaily follow: HP official video to Remove the Base Enclosure
    • Once you pull up the sides of the cover (e.g. with a pick). You will feel it is still attached in the middle. You can squeeze your hand under the enclosure and push from the middle to liberate a clip in the middle of the enclosure. Pulling directly from the sides feels like the cover will break.
    • If you are not sure of the model of the computer/battery. you can do this step to check the battery model before buying it and then close it again doing the inverse.
  2. HP Pavilion 14 Notebook Battery Replacement, Replace Battery: 2 단계, 이미지 2개 중 1개 HP Pavilion 14 Notebook Battery Replacement, Replace Battery: 2 단계, 이미지 2개 중 2개
    • You can check the battery model (top-left of the battery), for our case HT03XL, with this reference you will be able to get the propper replacement.
    • If you have the replacement you can unscrew the 5 P1 Philips screws. The top part will have the connector you will need to disconnect to remove the battery. You can follow HP official video to remove the battery
    • Connect the new battery and screw again the 5 screws.
결론
To reassemble the enclosure, clip it again and screw again the 5 screws (follow Step 1 instructions in reverse order).
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Oriol CN
회원 가입일: 12/31/22
125 평판
안내서 1개를 작성함
댓글 한 개
Nice explanation about the disassemble the hp notebook laptop. And replace the original battery replacement hp guide
Mahima Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 34
지난 30일: 152
전체 시간: 4,359
