주요 콘텐츠로 건너뛰기
HP Pavilion 14-b015dx Battery Replacement
  1. HP Pavilion 14-b015dx Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Battery Replacement: 2 단계, 이미지 1/1
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Battery Replacement: 3 단계, 이미지 1/1
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery by sliding it upwards and away from the computer.
결론
Gregory Bridge
회원 가입일: 10/24/17
623 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 회원
UMASSD-ISAACSON-F17S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 13
전체 시간: 654
