소개
Is your device not holding a charge or is unable to charge? If so, the battery may be faulty and needs to be replaced. Follow the instructions in this guide to remove and replace the battery in the HP Pavilion 14-cf0014dx laptop.
필요한 것
Flip the device over so that the backside is facing you.
Remove the rubber feet to expose six screws.
Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
For optimal performance, after completing this guide, calibrate your newly installed battery.
